Thank you, I assume from your answer that this explanation is not available in a public document.
I don't know if a 25hz servo rate is good enough for my mechanics, that is just a magic number a Hypertherm guru quoted one time. I am still building my new Z axis mechanics. Based on the performance of my X &Y axis I see no reason the actual Z maximum velocity and accelerations will be lower, same drive, same stepper, nearly same reduction, 1/4 the mass. My X and Y axis run reliably at 225ipm so if my Z can move that fast I should be able to cut some pretty wavy sheet, I will not be trying to cut corrugated sheet steel like some of the THC ads show. Some day I will shell out for 5 new Gecko drivers and power supply to boost my top end.
To increase the integration time do I need to instantiate a new thread running at the desired integration period? I assume that this is the thread that will call the THC component? I have not gotten to creating ini and HAL files yet, I only know that the communication between my PC and the 7i76E works!
