Problem with 7i80db_16_7i76x2_7i77x2D
- perra_e
16 Apr 2016 21:36 #73438
by perra_e
Replied by perra_e on topic Problem with 7i80db_16_7i76x2_7i77x2D
Ok, i do that tomorrow. Bedtime here now.
Thanks a lot so far.
--Per
--Per
- Thank you received: 5308
16 Apr 2016 22:23 #73440
Replied by PCW on topic Problem with 7i80db_16_7i76x2_7i77x2D
ill try and duplicate this in Monday
Does the green light on the 7I77 blink?
- perra_e
17 Apr 2016 08:22 #73462
by perra_e
I have tried loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=6 num_pwmgens=0 num_stepgens=1 sserial_port_0=000xxx sserial_port_1=000xxx with same result.
Green led is not blinking, so there is somthing wrong.
--Per
--Per
17 Apr 2016 13:50 #73474
What kind of cable is used between the 7I77 and 7I80?
- Thank you received: 4648
17 Apr 2016 14:45 #73480
Is it possible that the 7i77 is plugged into a DB25 connector that is now set up to be for a 7i76?
Replied by andypugh on topic Problem with 7i80db_16_7i76x2_7i77x2D
I flashed the 7i80db with the 7i80db_16_7i76x2_7i77x2D.bit
After reconfiguring my hal-file, linuxcnc starts again without error.
My problem is that I don't get any signals from the input on the 7i77. I have 24V on INPUT-00 but it shows off in HalView.
- perra_e
17 Apr 2016 14:47 #73481
by perra_e
I use this Cable
www.elfa.se/en/sub-cable-db25-maxxtro-aa-305-03/p/12511401
it is a shielded 25 pin d-sub Cable.
- perra_e
17 Apr 2016 14:49 #73482
by perra_e
Andy, I don't Think so. it is connected to the third db25 connector. If I connect it to any other connecter linuxcnc won't start.
17 Apr 2016 14:57 - 17 Apr 2016 15:03 #73484
That may be a problem, thats not a IEEE-1284 compatible cable so will likely have a lot of crosstalk between signals
(IEEE-1284 cables have a separate ground wire for each signal)
There have also been some improvements in the SmartSerial FPGA firmware to make it more robust
when dealing with poor signal quality due to wiring issues so updating the firmware may help
(I will have to rebuild since the 7I80 firmwares have not been updated for more than a year)
Last edit: 17 Apr 2016 15:03 by PCW.
- perra_e
17 Apr 2016 15:05 - 17 Apr 2016 15:07 #73485
by perra_e
Yes, that could be it. Strange it works perfect with the other bitfile, but maybe som other pairs are use in that configuration.
I shall see if I can get one or borrow one.
btw, I'm just ready with the tool change sequence. It's only the carousel left now.
First toolchange
First toolchange
Last edit: 17 Apr 2016 15:07 by perra_e.
17 Apr 2016 15:38 #73486
So that does suggest another problem (I do notice a comment in my firmware that says that config just barely fits in a -16 part)
What actual hardware do you have?
Time to create page: 0.865 seconds
