Problem with 7i80db_16_7i76x2_7i77x2D
17 Apr 2016 15:45 #73488 by perra_e
Replied by perra_e on topic Problem with 7i80db_16_7i76x2_7i77x2D
I have one 7i80db 16, one 7i77 and I actually don't have a 7i76 card. I only need one hardware stepgen for the toolchanger and my plan was to use this config for that and just add two optocouplers to the output pins on the 7i80. I also have a 7i73, but that is not connected yet.
--Per
17 Apr 2016 15:53 #73489 by perra_e
About a month ago I tried to make a new bitfile, just to add the stepgen. I compiled the 7i77 x 4 source first without any changes but I never got it to work so I waited to try the software stepgen first. Then I found out that the m7i76, 7i77 should work but it has not so far.
17 Apr 2016 16:05 #73490 by PCW
Replied by PCW on topic Problem with 7i80db_16_7i76x2_7i77x2D
give this bitfle a try
freeby.mesanet.com/7i80db16_7i76x2_7i77x1D.bit
(7I77 I/O numbering will be different )
17 Apr 2016 17:07 #73492 by perra_e
We are almost there. Communication works with that one!
Only problem with this is that analog pins are missing
hm2_7i80.0.7i77.0.7.analogout0-scalemax for instance.
I attach a textfile with show pin.
--Per
File Name: pins.txt
File Size:24 KB
17 Apr 2016 17:57 - 17 Apr 2016 18:01 #73496 by PCW
I had the sserial port order wrong in that config
try fetching it again
(7i77 ports will be 4 for DIO and 5 for analog)
Last edit: 17 Apr 2016 18:01 by PCW.
17 Apr 2016 18:28 #73498 by perra_e
And now it works. You are a hero!!!
Thanks Peter.
--Per
18 Apr 2016 20:21 #73567 by perra_e
Today I have tested with the steppermotor and the carousel and I just wanted to give some feedback and tell it works perfect!
--Per
Moderators: PCWjmelson
Time to create page: 0.639 seconds
