Disabling servo amps.
- Thank you received: 5335
12 Jun 2016 23:05 #75887
Replied by PCW on topic Disabling servo amps.
you can verify that hm2_5i25.0.7i77.0.1.analogena toggles
(with halmeter or show hal configuration --> "watch")
If the OPTO is fried it will likely just be always open
you can check safely with an Ohmmeter
The following user(s) said Thank You: sliptonic, Catch22
- sliptonic
- Thank you received: 22
19 Jun 2016 21:17 #76294
by sliptonic
Replied by sliptonic on topic Disabling servo amps.
Finally found the last loose connection. Thanks everyone!
The following user(s) said Thank You: Catch22
- Catch22
- Thank you received: 17
23 Feb 2020 16:58 - 25 Feb 2020 13:30 #158311
by Catch22
Replied by Catch22 on topic Disabling servo amps.
I am in the process of doing the same thing except my drives are a bit bigger,25a20 AMC drives, could you point me in the right direction on what relay I should get and what size of diode.
Thanks Mike
Thanks Mike
Last edit: 25 Feb 2020 13:30 by Catch22. Reason: Spelling mistake
Time to create page: 0.237 seconds
