Connect spindle VFD to 7i76e, DIR not working
  • newbynobi
  • newbynobi's Avatar Topic Author
  • Platinum Member
  • Platinum Member
13 Aug 2016 14:09 #78707 by newbynobi
Hallo,
Please find attached the connection diagram of my VFD,
This browser does not support PDFs. Please download the PDF to view it: Download PDF
My spindle does 6000 rpm.
I have 10 V on PIN 3, PIN 6 and PIN 8
Giving in MDI
S3000 M3
I get 5 V on PIN2 and 10V on PIN 6 (TB4)
No voltage on PIN 7 of TB4 (thats OK)
Now I do a
S3000 M4
No voltage on PIN 7 of TB4 (thats NOT OK)
So spindle does not change direction, as the reverse signal does not arrive at the VFD.
Whatching with halshow:
hm2_7i76e.0.7i76.0.0.spindir
hm2_7i76e.0.7i76.0.0.spinena
hm2_7i76e.0.7i76.0.0.spinout
shows that spindir does get TRUE if I start spindle with M4
Any ides what I am making wrong?
Norbert
P.S. Firmware on 7i76E is hm2/7i76/7i76e_7i76x1_7i74x1D.BIT, flashed about 2 Month ago
13 Aug 2016 14:22 - 13 Aug 2016 14:22 #78709 by PCW
Can you check nothing connected except a Ohmmeter across pins 7 and 8 ( + to 8 )
if the meter reading does not change with hm2_7i76e.0.7i76.0.0.spindir state
I would suspect a bad OPTO
Note that you cannot use the screws on the top of the connectors
to measure unless the screws are tight
Last edit: 13 Aug 2016 14:22 by PCW.
  • newbynobi
  • Platinum Member
  • Platinum Member
13 Aug 2016 14:39 #78711 by newbynobi
Replied by newbynobi on topic Connect spindle VFD to 7i76e, DIR not working
Hallo PCW,
checked without the plug and nothing connected:
hm2_7i76e.0.7i76.0.0.spindir = True = about 15 k Ohm
hm2_7i76e.0.7i76.0.0.spindir = False = M Ohm, out of range of my Multimeter
So something is changing.
I checked also
hm2_7i76e.0.7i76.0.0.spinena = True = about 15 k Ohm
hm2_7i76e.0.7i76.0.0.spinena = False = M Ohm, out of range of my Multimeter
So they are behaving the same, but one does work, not the other :(
Norbert
  • newbynobi
  • Platinum Member
  • Platinum Member
13 Aug 2016 14:50 #78712 by newbynobi
Solved!!!
As it did work without the plug, I measured again with the plug an tighten screws.
Not working.
I took an unused plug from TB6 with the same connections
All OK!!!!
I have never had a brocken plug, but that seems to be the secret.
At least it is working now!
Thanks from Norbert for pushing me in the right direction.
13 Aug 2016 15:19 #78713 by PCW
Sorry for the bad plug
I don't actually think I've seen one before
Glad you are up and running again
Moderators: PCW, jmelson
Time to create page: 0.094 seconds
