MESA Card Recommendation
  • Chathuranga555
  • New Member
  • New Member
7 years 5 months ago #132483 by Chathuranga555
Replied by Chathuranga555 on topic MESA Card Recommendation
hi guys,
I am a beginner of LINUXCNC and there is a 3 Axis wood router machine with 4 spindle drivers and large number of drilling, routing tools and hundreds of I/O. And the existing controller is not functioning, so my boss asked me to try to replace the controller with linux cnc & mesa card. What card is the best solution for my requirement.
I have mesa 5i24 & 2x 7i48 cards. Are they suitable for my requirement?
Please help me for these 2 questions.
7 years 5 months ago #132491 by pl7i92
Replied by pl7i92 on topic MESA Card Recommendation
Hi
as the Mashine seams Servo 7i48 you are fine
you can go with your mesa cards they will work as you think
the 5i24 and 7i48 can drive your spindles as well
you are in good setup maybe you shoudt consider a 7i34 for the RS485 Modebus comunication to the Spindles
as well as a 7i73 or a 7i42 for the IO you need
The following user(s) said Thank You: Chathuranga555
  • Chathuranga555
  • New Member
  • New Member
7 years 5 months ago #132508 by Chathuranga555
pl7i92 wrote: Hi
Thank you for your help.
Could you please let me know how to run my spindles with 7i48 card.
7 years 5 months ago #132515 by tecno
Replied by tecno on topic MESA Card Recommendation
Assuming your servo drivers are analog ±10V controlled you should be OK.
7 years 5 months ago #132521 by pl7i92
the 7i48 you got 2 of them got enoph analog out to drive the spindles as i count 12AXIS servos available
so simply use more then 1 pidloop to get them run
you need 3/4 Analog for your Woodrooter so 2/3 Spindles on the First 7i48
then you got 6 more spindle to control on the second 7i48
7 years 5 months ago #132530 by PCW
Replied by PCW on topic MESA Card Recommendation
Typically with the system you have you would use a 7I37TA for general purpose I/O
As techno mentioned, the 7I48s are for interfacing with analog +- 10V servos or
+-10V,0 --> 10V spindles
Moderators: PCW, jmelson
