MESA Card Recommendation
9 years 4 months ago #94940 by jmelson
Replied by jmelson on topic MESA Card Recommendation
If you are using steppers, another option is the Pico Systems Stepper controller. It supports up to 4 axes, and can be extended with another board for up to 8 axes. it can accommodate steppers with encoders, if you want that. It also has inputs for limit and home switches, and positions for 8 solid state relays to control spindle, coolant, etc.
An optional board can give an analog spindle speed output.
See pico-systems.com/osc2.5/catalog/product_...ath=4&products_id=30
for more info. It interfaces via the parallel port. if your computer doesn't have a parallel port, you can get PCI or PCIe cards to provide that. (We sell the PCIe cards to assure they are compatible.)
This works out of the box with LinuxCNC, where a sample config file is provided.
Jon
The following user(s) said Thank You: Jono
9 years 4 months ago #94964 by Clive S
Replied by Clive S on topic MESA Card Recommendation
PCW wrote: In the last couple of days a new LinuxCNC/Debian stretch ISO has been released
which includes a uspace version of LinuxCNC with a Preempt-RT kernel
This will work as is with any of the Mesa Ethernet cards like the 7I76E
Would you mind pointing to a link for this please and is it independent ie not requiring any other patches.
9 years 4 months ago #95012 by rodw
9 years 4 months ago #95022 by Clive S
rodw wrote: Follow this thread for a link
forum.linuxcnc.org/9-installing-linuxcnc...retch?start=20#95011
Thanks Rod I did read that thread but I get confused with :-
Parent Directory -
linuxcnc-stretch-uspace-amd64-r1.iso 23-Jun-2017 17:13 1.1G
linuxcnc-stretch-uspace-amd64-r1.iso.zsync 23-Jun-2017 18:40 2.1M
linuxcnc-stretch-uspace-i386-r1.iso 23-Jun-2017 17:06 1.1G
linuxcnc-stretch-uspace-i386-r1.iso.zsync 23-Jun-2017 18:40 2.2M
v0.iso 21-Jun-2017 18:11 2.0G
v0.iso.zsync 21-Jun-2017 18:11 3.9M
Which is the correct one to down load ie what is zsync?
9 years 4 months ago #95023 by tecno
Replied by tecno on topic MESA Card Recommendation
r1.iso either 64 bit or 32bit
9 years 4 months ago #95024 by rodw
Replied by rodw on topic MESA Card Recommendation
I see you found your your way to the other thread:
i386 = 32 bit
amd64 = 64 bit
Zsync is a file transfer program but I think it also allows you to (z)sync a remote .iso to your PC without having to download the complete .iso every time it changes.
Moderators: PCW, jmelson
Time to create page: 0.360 seconds
