need help 5i25/7i76 setup for plasma
9 years 2 months ago #98347 by bevins
kb8wmc wrote: Rod, thank you much for your information and suggestions...I appreciated it...I am still working on the getting a limit switch working, I think my problem is in my HAL setup...
Thanks again...
kb8wmc
Connect your input to limit-X in HAL, but don't forget the check the limit switch entries in the ini file. That will determine if and how they work.
9 years 1 month ago #98736 by kb8wmc
My progress thus far...
I now have two motors connected and operational for testing...connected three home/limit switches in series NC configuration...I removed or commented out all parallel port references, so that I have only made reference in hal and ini files to connections and hardware to be recognized via 5i25/7i76 Mesa...Initially had problems with the actual names of the pins that were relevant to the limit/home switches...I was able to remedy the improper names and spelling by reading lots of posts in the forums...I learned quite a bit about how the actual component names work and relate to HAL...BUT, along the path of learning I found that what is called out and used generally for the naming conventions to be used by HAL, (e.g. hm2_5i25.0.7i76.0.0.input-00) does not work with my boards....Instead I have to identify by the number of the gpio pin in order not to get a complaining error about no such pin, (e.g. hm2_5i25.0.gpio.004.in)...
At present my limit switch is being provided field power and when checked with multimeter is functioning properly...One leg to field power terminal 2 and the other to TB6 pin 004...The problem is that the when I test the homing function the switch does not perform the homing function...I can see the switch in HAL show, but no change occurs when I trip the lever...
I feel there is something that I am missing like a setp something or other, but I can find no examples in my searching for answers...I am almost at my wits end...Any guidance will be appreciated...
9 years 1 month ago - 9 years 1 month ago #98737 by PCW
The GPIO pins on a 5I25/7I76 interface are not of _any_ use
You must use the hm2_5i25.0.7i76.0.0.input-xx pins to use the field I/O inputs
if the hm2_5i25.0.7i76.0.0.input-xx pins are not present this is usually some kind of hardware setup issue
common problems:
1. No 5V to 7I76 ( set 5I25 to supply 5V to 7I76 and 7I76 to get 5V from --> 5I25 = 5I25 W2 up, 7I76 W2 left )
2. No field power at startup
3. 7I76 Setup/operate jumper in setup mode (must be in operate mode)
4. Wrong firmware in 5I25 (check with mesaflash)
5. 7I76 not connected to 5I25 P3 with IEEE1284 cable
Last edit: 9 years 1 month ago by PCW.
9 years 1 month ago #98741 by kb8wmc
PCW,
Your information solved my limit/home switch problem....The W3 jumper was set to setup mode...I switched it to operate mode and it works as it should now....Next will be the touch-off/probe for the torch and the emergency stop switch...
The commands code now looks like everyone else's examples of code...Will keep informed of my progress...
Thank you so much PCW
9 years 1 month ago #99277 by kb8wmc
Thanks to the input from folks I have motion of the machine with active home/limit switches...
This is 5i25/7i76 ---- THCAD-10
Hypertherm PowerMax 45
Presently at the point where we need some guidance on connecting the six wire + ground coming from the PM45 into the THCAD-10 and whatever else...We can identify where the +IN and -IN from the PM45 attach to the terminals on the THCAD-10, but there are 4 other wires and a ground wire that go someplace, but I am not clear to where they attach...
Any direction will be appreciated....
9 years 1 month ago #99287 by rodw
Moderators: PCW, jmelson
Time to create page: 0.063 seconds
