The VFD panel Potentiometer turns the Spindle succesfully. Known Good.
Diagnostic Configuration:
Attempt to run the VFD9600 with a 0-10V Analog source POT that is not the 7i76 firstly to test Pinout function....
Diagnostic Test Pin Functions for
A1 :: ACOM
FWD/REV :: DCOM
Other than panel Pot, I do not have a external seperate non-mesa, non-7i76
0-10V Adjustable Power Supply Pot for "voltage applied to A1 (relative to ACOM)"
Option
No External Pot, use External 5V Power Supply & Switch On/Off
Attribute VFD9600 for "Slow Acceleration Time" to avoid "Jump Starting the Spindle to the 5V RPM/HZ value"
Apply 5V + to A1
Apply 5V - to ACOM
Would this diagnostic be safe to attempt?
PNCConf
0: Spindle Output POT Output
0: Spindle Output POT Enable
Analog Max Voltage = 10.00
RPM Max = 24,000
I have reverted the VFD 9600 settings to Terminal Pins Control and evaluate
Connect FWD and REV to DCOM
To clarify,
DCOM is the VFD 9600 Digital Common Ground?
For the 7i76 10V Analog setup? DCOM? Not ACOM for Analog 10V?
FWD = 7i76 ENA+ CONNECT TO VFD9600 DCOM
REV = 7I76 DIR- CONNECT TO VFD9600 DCOM
Or to Clarify:
FWD = VFD9600 X5 FWD to VFD9600 DCOM
REV = VFD9600 X6 REV to VFD9600 DCOM
VFD9600 X5 Function:
1: Forward RUN (FWD)
2: Reverse RUN (REV)
4: Forward JOG (FJOG)
5: Reverse JOG (RJOG)
6: Terminal UP
7: Terminal DOWN
8: Coast to stop
