8i20 with 7i77/7i74 combo
21 Nov 2017 23:08 #102158 by bevins
Replied by bevins on topic 8i20 with 7i77/7i74 combo
They are Optical encoders with two sets output that goes into the drive. one is quad diff I think and the other set is single ended.
1st output
PA0
/PA0
PB0
/PB0
PC0
/PC0
2nd output:
PHA
PHB
PHC
I am pretty sure I can connect these to a 7i77 and they will work.
21 Nov 2017 23:12 #102159 by bevins
My bad wrong side again. see attached.....
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
21 Nov 2017 23:17 #102160 by tommylight
Replied by tommylight on topic 8i20 with 7i77/7i74 combo
That looks promising for sure, especially the part with UVW !!! I can bet my beehind those can and are used for commutation !
Now to figure out how exactly.
Bevins, thank you.
22 Nov 2017 00:07 #102163 by bevins
The UVW are hall commutation signals and they provide trapezoidal commutation of the motor.
Just read that.
  • Moderator
  • Moderator
22 Nov 2017 00:21 #102165 by tommylight
Will do, i need more food for the brain.
Thank you.
22 Nov 2017 00:28 #102166 by andypugh
Replied by andypugh on topic 8i20 with 7i77/7i74 combo
If you have UVW then it is all suddenly very easy :-)
22 Nov 2017 02:28 - 22 Nov 2017 02:41 #102171 by bevins
Then the hardest part now rhen becomes getting a hold of some 8i20cards.
Doesnt seem like any are available.
Last edit: 22 Nov 2017 02:41 by bevins.
22 Nov 2017 03:56 #102174 by jmelson
Replied by jmelson on topic 8i20 with 7i77/7i74 combo
Question : regarding hal sensors, does it have to be only one, or 3 for each winding one? What about placement? They must be at a certain place inside the motor?
There would normally be 3 Hall signals that ripple in a 120 degree phase relationship. US Digital, Renco and Avago make "six channel" encoders that have both ABZ and Hall outputs in one encoder. You have to order the disc that has the right number of motor poles to match the motor windings/magnets.
The encoder disc then has to be aligned to the motor poles.
The Hall sensors do not actually have to be inside the motor.
Jon
22 Nov 2017 13:18 #102182 by andypugh
If we have decided that you have Hall sensors then you could look at the Pico drives.
pico-systems.com/acservo.html
22 Nov 2017 14:20 #102185 by bevins
I thought of those but they are only good to 120v 20A output.
Dont think they will take the big 1.8KW aC servo's from Yaskawa. Not sure but my gut feeling is they wont.
Moderators: PCWjmelson
Time to create page: 0.244 seconds
