Finally we have tested the firmwares.
On 7i92 it works good.
But on the 5i25 0-3 channels a lot have of noise. Especially when we power up the servo. See attached halscope screenshot - sharp spikes on the signal. Channels 4-7 work good. May be there's a bug in the firmware?
By the way we've found that 8xRJ45 connector's shield is not grounded, so until we connected it to the ground we had a lot of noize on the ssi channels. I've not found anything about that in the manuals.
Another thing - using pair of 7i92+7i77 we have some notches on the 4th analog out (other channels work fine). Notches appears mostly near 0 output value from one to ten seconds per notch. We have tried to change 3 different 7i77, changed the cables with no effect, but if we connect the same 7i77 board to 5i25 everything works smooth.
