freeby.mesanet.com/ssid200.zip
7i92 and 5i25 7i77_7I74 SSI configs plus changed sources
These have a 200 ns fixed digital filter on the SSI data
On the analog output problem, this may be a solved issue, are you using the latest version of linuxCNC?, there was a sserial race bug found in the driver a couple of months ago (Doit Issued before all transfer data registers written) this would likely show up as corrupted data on a particular data register and would explain the 5I25/7I92 difference (different register write timing)
