7i80 kernel
- Thank you received: 5296
11 Feb 2018 16:02 #105748
Replied by PCW on topic 7i80 kernel
The bitfile for 1 to 4 7I40 and a 7I37 is 7i80hd_25_svst8_4.bit or 7i80hd_16_svst8_4.bit
The following user(s) said Thank You: billykid
- billykid
- Thank you received: 82
11 Feb 2018 19:31 #105760
by billykid
Replied by billykid on topic 7i80 kernel
But I have a 7i80db-16 as I said, but it's not a problem if it's about changing wires. the important thing that can go.
but in the 7i80 folder there are no files for this ..
Mauro
Mauro
- billykid
12 Mar 2018 08:46 #107237
by billykid
hi Pcw
I modified this svst8_4 to use it on my 7i80db16 and it works.
I have deliberately put this order of the axes because Y and Z are 30 volts motor on a 7i40 and X and a 60 volt motor spindle.
I would like to know if it is done correctly and if I can also post the .BIT file if it can help someone.
best regards
Mauro
best regards
Mauro
