custom mesa implementation
- Thank you received: 5325
23 Nov 2018 18:34 #121260
Replied by PCW on topic custom mesa implementation
My guess is for a 5I20 (or other SpartanII based card) you will have to comment out the SimpleDSAD module in the HostMot2 source file
23 Nov 2018 19:18 #121264
I will try to make a Spartan-II compatible source snapshot for older cards when I get a chance.
A lot of the issues are with the fact that you need to use a quite old compiler
for Spartan-II, and that i have not tested builds on the old compiler for at least a
couple of months, so the current snapshot has many issues with ISE 9.x
- tjtr33
- Thank you received: 54
24 Nov 2018 02:40 #121281
by tjtr33
Replied by tjtr33 on topic custom mesa implementation
Thx PCW
1) can i use the new tools? ( web sez i have to use 9.2 for Spartan2)
I'll gladly change if it makes life easier.
2) I commented out the rather large code section in hostmot2.vhd concerning simpldsad, and now it complains
ERROR:HDLParsers:3014 - "/home/tomp/Xilinx92i/mesaSources22nov2018/5i20/CONFIGS/HOSTMOT2/SOURCE/hostmot2/Top9030HostMot2.vhd" Line 81. Library unit i65card is not available in library work.
despite this in Top9030HostMot2.vhd
select one card type
--use work.@Card@.all;
use work.i20card.all; -- needs 5i20.ucf and SP2 200K 208 pin
--use work.i65card.all; -- needs 4i65.ucf and SP2 200K 208 pin
so dont go down that path
oh well part 2 (fleetwood mac)
tomp
tomp
24 Nov 2018 15:07 #121292
No unfortunately ISE 9.2 is the latest that supports SpartanII chips
The i65card error is weird, maybe something else broken (might try removing i65card.vhd from the source list)
As i mentioned, I will make a Spartan2/ISE9.2 source/project dist but i wont be able to do this until Monday
- tjtr33
25 Nov 2018 17:51 #121327
by tjtr33
Thx PCW,
No need to make the project dist.
I can build now. I didnt have the webupdates.
Manually installing SP1,2,3,4 made it work.
Note to others adventurers:
When you install and the webupdate fails and it wants you change proxy settings in your Mosaic browser (
... dont believe 'em.
Just manually downlad the 4 service packs and install using these notes www.xilinx.com/support/answers/25384.html .
Also install all of them and in numerical order,
TomP
TomP
Time to create page: 0.288 seconds
