Encoder ppr?
08 Jun 2018 09:25 #111977 by CNCDoc
Encoder ppr? was created by CNCDoc
Hello, plan to convert a Modig MD5000 from TNC150 to Linuxcnc.
Planning to use 5i25 + 7i77 kit after talking with one that made a similar conversion.
My first question concerns the encoder. How many pulses can you recomend?
My plan is to reuse my Contraves DC servon. Is there anybody who has tips on 6mm axle pulse encoder?
Attaches images with dimensions and mounting on current sensors with wrong signal.
Have a look at these encorders: www.digikey.se/products/en/sensors-trans...0&page=1&pageSize=25
Excuse me for my bad English.
08 Jun 2018 11:55 #111988 by CNCDoc
08 Jun 2018 12:06 #111991 by tecno
Replied by tecno on topic Encoder ppr?
Why 10000ppr? Varför som sagt?
08 Jun 2018 12:11 #111992 by CNCDoc
Replied by CNCDoc on topic Encoder ppr?
Just chose one for example. How many ppr are usually? Have searched but not a good answer.
Hej du :-)
08 Jun 2018 12:14 #111993 by tecno
I think most common are 2500ppr or there about, the ones I have on my AC servos are 3000ppr.
09 Jun 2018 01:35 #112037 by andypugh
Replied by andypugh on topic Encoder ppr?
How fast do the servos rotate? If you use the 7i77 then I think you can count pulses at 10MHz.
Also calculate what spatial resolution your encoders give you. Much less than the width of an atom and you are wasting money :-)
11 Jun 2018 18:10 #112210 by CNCDoc
Max. motor speed is ~3000 RPM / 60 = 60 RPS. Encoder PPR is 3600
Max. frequency output of encoder at ~3000 RPM. 60 RPS x 3600 PPR = 180 Hz.
The pitch of the ball screw is 5mm / rev.
3600ppr the encoder 50 tenths of mm. 3600/50 = 72pp / 0.1mm
Wrong or right?
Good or bad?
11 Jun 2018 18:25 - 11 Jun 2018 18:26 #112211 by PCW
Replied by PCW on topic Encoder ppr?
I get 3600PPR @3000 RPM = 50 RPS* 3600 = 180 KHz A/B signals and 720 KHz count rate (4X 180KHz)
at 5 mm/turn and 4X3600 counts per turn that's ~0.347 microns per count
Last edit: 11 Jun 2018 18:26 by PCW. Reason: silly math error
12 Jun 2018 07:35 #112226 by CNCDoc
I see what I did wrong. Thanks for the help !
Is it overcrowded with 3600ppr?
Difference between 1500ppr and 3600ppr encorder is 57.6 usd.
Anyone who has experience with CALT encorder?
12 Jun 2018 09:07 #112228 by andypugh
I would say that the more resolution you have the better, up to the point that you overload the counter.
720 kHz is comfortable for the Mesa counters (I think they can go to 10MHz with the filters turned off)
What sort of accuracy are you hoping for? Your PID loop needs a few counts error to work with. 0.3um encoder resolution probably translates to no better than 5um positional accuracy. 1500 ppr would thus be about 10um accuracy. I would imagine that this is OK for a mill, good for a router and a bit worse than you would hope for on a lathe.
You might want to consider a belt reduction between the motor and the ballscrew. You can gain resolution and force at the expense of speed. 3000rpm and 5mm pitch is a top speed of 250mm/sec. For a big router that might seem slow, for a small lathe it might seem fast.
Moderators: PCW, jmelson
Time to create page: 0.263 seconds
