Can't get Mesa 7i92 to connect without a hub.
  • scubawarm
  • scubawarm's Avatar Topic Author
  • Premium Member
  • Premium Member
14 Jun 2018 19:56 - 14 Jun 2018 19:58 #112373 by scubawarm
OK GUI pops right up if I run through a hub. (Which I want to get rid of).
NOTE: a regular cable gets me no where.
Made a crossover cable.
Purchased an adapter to change a patch cable to crossover.
Purchased a cat 6 shielded crossover cable.
Spend most of the day trying all sorts of network configurations with no improvement. Is my card bad or what?
All three of these give me this... Find the card and MAC but error out.
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/superman/linuxcnc-dev/bin
LINUXCNC_TCL_DIR=/home/superman/linuxcnc-dev/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/superman/linuxcnc-dev/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/superman/linuxcnc-dev/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/superman/linuxcnc/configs/esab'
Machine configuration file is 'esab.ini'
INIFILE=/home/superman/linuxcnc/configs/esab/esab.ini
VERSION=1.0
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Found file(REL): ./esab.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=2050
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.100.100.121: Hardware address: 00:60:1b:13:00:9d
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
Board hm2_7i92.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_7i92.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_7i92.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.1 Software Mode 0 = analogout_enables
board fails HM2 registration
hm2: unloading
Debug file information:
Note: Using POSIX realtime
Waiting for component 'hm2_eth' to become ready...........................hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./esab.hal:9: waitpid failed /home/superman/linuxcnc-dev/bin/rtapi_app hm2_eth
./esab.hal:9: /home/superman/linuxcnc-dev/bin/rtapi_app exited without becoming ready
./esab.hal:9: insmod for hm2_eth failed, returned -1
2050
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Last edit: 14 Jun 2018 19:58 by scubawarm.
14 Jun 2018 20:51 #112374 by PCW
Can you ping the card with a straight through cable?
What firmware are you using?
  • scubawarm
  • Premium Member
  • Premium Member
14 Jun 2018 21:32 - 14 Jun 2018 21:34 #112375 by scubawarm
Replied by scubawarm on topic Can't get Mesa 7i92 to connect without a hub.
Now I can ping with a patch cable.... Didn't think that worked before.
When I boot the GUI same result.
7i92._7i77_7i76D.bit
Last edit: 14 Jun 2018 21:34 by scubawarm.
14 Jun 2018 21:34 #112376 by PCW
what result?
  • scubawarm
  • Premium Member
  • Premium Member
14 Jun 2018 21:39 #112377 by scubawarm
Same as I posted above. Discovers, and gets MAC address but errors out and doesn't load.
Put on a hub pops right up.
These ports are 100MB Full?
14 Jun 2018 21:50 #112378 by PCW
Not sure whats going on, sounds like dropped packets, maybe something marginal on either the 7I92 or the host.
What is the host PC and host MAC?
Does ping ever drop packets?
  • scubawarm
  • Premium Member
  • Premium Member
14 Jun 2018 22:21 #112379 by scubawarm
Away from the screen now so can't get MAC. .120 ending IP
The little host unit is XCY 1900 with 4 Intel gigabit ports. These are used world wide with pfSence on them for professional high speed routers. So have trouble believing it is the problem. Only using one port at a time and tried them all.
I don't actually like that the only network change you make on Mesa is the IP number.
Never drops a packet.
14 Jun 2018 22:32 - 14 Jun 2018 22:44 #112381 by PCW
I didn't mean the Hosts MAC address but rather the type
SInce these are Intel MACS, did you turn IRQ coalescing off?
(it plays havoc with real time)
What OS are you using? (uname -a)
Last edit: 14 Jun 2018 22:44 by PCW.
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
14 Jun 2018 22:59 #112382 by ozzyrob
Replied by ozzyrob on topic Can't get Mesa 7i92 to connect without a hub.
Is it unusual for this to happen prior to loading the hm2 modules ?
14 Jun 2018 23:40 #112383 by PCW
Also can you post your hal/ini files? there's something odd about the messages as ozzyrob noticed
Moderators: PCWjmelson
Time to create page: 0.287 seconds
