drive small dc servos
18 Jul 2018 04:51 - 18 Jul 2018 05:58 #114443 by vre
Replied by vre on topic drive small dc servos
I have build a co2 laser with chinese controller and cheap glass tube
and am getting far more better results from that you get.
I think your results are unacceptable to be sold and iam saying that because i have sold over 50 portraits in granite.
30x40 portrait about 45mins.
Yes hammering is slow but sauno hammering machines are the best
and produce better results than other similar machines.
The bad of laser is that it needs totally black granite.
Hammering works and in not so black granite.
From these 2 H bridges witch is better?
www.ebay.com/itm/DC-12V-24V-36V-H-Bridge...8000?epid=1494614167
www.ebay.com/itm/Dual-Motor-Driver-DIY-M...Peak30A/302468611608
Last edit: 18 Jul 2018 05:58 by vre.
20 Jul 2018 10:34 #114580 by vre
Linuxcnc CAN do raster engraving provided the gcode.
It can do almost anything any other machine can do. It is a machine controller, not a CAD/CAM !
I use it for raster engraving on many machines as you can clearly see on the link above and on my youtube channel.
How can i do raster engraving at constant speed with mesa card ?
22 Jul 2018 22:29 - 22 Jul 2018 22:30 #114678 by vre
PCW Can you make a firmware for me?
for 7I80HD-16 with
3 pwm generators to drive 3 brushed dc servos for XYZ
3 incremental quadrature encoder readers
1 step - dir to drive a stepper for rotary axis
datapainter module to drive an rf co2 synrad (J48-2) (5khz pwm modulation + 5khz tickle signal 1us pulse width)
rest I/O - half inputs half outputs.
Also with what ethernet cards is compatible 7i80hd ?
Thank you.
Last edit: 22 Jul 2018 22:30 by vre.
30 Sep 2021 22:45 #221922 by markusk
Replied by markusk on topic drive small dc servos
Hello @vre,
it seem i have a similar if not even the same trotec machine. the date on my pittman motors is 8 days after yours ;)
did you ever get to controlling the inbuilt tube? i'm just starting out researching about this, would like to reuse the laser on a bigger frame for cutting.
thanks,
markus.
30 Jun 2023 09:09 #274494 by ValentinD
Replied by ValentinD on topic drive small dc servos
Hi @vre,
i also have a similar laser with a broken controller.
I had the same idea as you, using a ruida controller and leadshine dcs810s to retrofit the machine.
Did you finish this project, did everything work?
How are the leadshine servo drivers performing?
Do you have any advice for me?
Thanks in Advance,
Valentin
Moderators: PCW, jmelson
Time to create page: 0.082 seconds
