Analog linear encoders
01 Aug 2018 15:42 - 01 Aug 2018 15:44 #115316 by jmelson
Replied by jmelson on topic Analog linear encoders
Well, this is only part of the story. What you want is a "current to voltage converter" circuit, which is basically an op amp with a resistor between the output and the inverting input. (The non-inverting input would be tied to a constant mid-value voltage that is proper for the scale's circuitry.) The sine wave current is also applied to the inverting input. The resistor value is chosen to get the uA current up to a meaningful (voltage) level. You can then "slice" this with a comparator or even a Schmitt trigger chip.
This will only give you the native resolution of the scale. So, if it has 100 lines/mm (10 um resolution) you will get 4X that in quadrature, so 400 counts/mm. If that is satisfactory, then it is easy. If that is NOT enough resolution, then you need an interpolator box, which will be somewhat expensive.
Jon
Last edit: 01 Aug 2018 15:44 by jmelson.
The following user(s) said Thank You: OT-CNC
01 Aug 2018 22:03 - 01 Aug 2018 22:05 #115349 by vre
Replied by vre on topic Analog linear encoders
@jmelson
What is this Vpp sin-cos or Ipp sin-cos ?
And what 15V / 7.5V and U3 do ?
Last edit: 01 Aug 2018 22:05 by vre.
Moderators: PCW, jmelson
Time to create page: 1.135 seconds
