5i25 and 7i77 Do I need to reflash?
8 years 1 month ago #117235 by PCW
Your firmware is fine, no need to change it
8 years 1 month ago #117237 by cncnoob1979
I just tried Path Pilot and it works fine.... with the exact same configuration that Im using in linuxcnc. The hal and Ini are derivatives of my linuxcnc configuration.
I can home, jog and use as normal. So the card/encoders/servo's functions correctly.... I did just build another linuxcnc master. Ill build the latest stable and see if this is my issue.
8 years 1 month ago #117238 by cncnoob1979
Alright 2.7.14 build in progress. Ill update when its done and if that was my issue.
8 years 1 month ago #117241 by cncnoob1979
Ok that did not work. Im on 2.7.14 and exact same symptoms. Path Pilot works fine.
I want to go through the relfash procedure. Peter please let me know which bit file I need to use. This may not be the issue as you have already pointed out, but I'm at my wits end. I never had any issue with my setup or configuration. I have even tried my backup configurations.
I copied over path pilots ini and hal file and tried that setup as well. Still the same issue (after editing them of course)
Something is squirrelly
Does anything pop out at you looking at my Hal and INI files? Maybe I changed something a year ago, but that doesnt explain Path Pilot working without a hitch, using the same configuration.
hal file
# Generated by PNCconf at Mon Jan 18 14:56:08 2016 # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt trivkins loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES loadrt hostmot2 loadrt hm2_pci config=" num_encoders=5 num_pwmgens=5 num_stepgens=0 sserial_port_0=100xxx" setp hm2_5i25.0.watchdog.timeout_ns 5000000 loadrt pid names=pid.x,pid.y,pid.z,pid.s loadrt oneshot names=os1,os2,os3,os4,os5 loadrt not count=4 loadrt conv_float_s32 names=cnvf,cnvr,cnvs loadrt debounce cfg=2 loadrt and2 count=12 loadrt or2 count=10 loadrt toggle count=1 loadrt toggle2nist count=1 loadrt flipflop names=ff1,ff2 loadrt near count=2 loadrt scale names=scale.sp,scale.jog,scale-fo,scale-ro,scale-so,scale-maxa loadrt abs names=abs.spindle loadrt lowpass names=lowpass.spindle loadrt limit1 count=2 loadrt limit2 count=1 loadrt mux2 count=3 addf hm2_5i25.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.x.do-pid-calcs servo-thread addf pid.y.do-pid-calcs servo-thread addf pid.z.do-pid-calcs servo-thread addf pid.s.do-pid-calcs servo-thread addf hm2_5i25.0.write servo-thread addf os1 servo-thread addf os2 servo-thread addf os3 servo-thread addf os4 servo-thread addf os5 servo-thread addf not.0 servo-thread addf not.1 servo-thread addf not.2 servo-thread addf cnvf servo-thread addf cnvr servo-thread addf cnvs servo-thread addf debounce.0 servo-thread addf and2.0 servo-thread addf and2.1 servo-thread addf and2.2 servo-thread addf and2.3 servo-thread addf and2.4 servo-thread addf and2.5 servo-thread addf and2.6 servo-thread addf and2.7 servo-thread addf and2.8 servo-thread addf and2.9 servo-thread addf and2.10 servo-thread addf and2.11 servo-thread addf or2.0 servo-thread addf or2.1 servo-thread addf or2.2 servo-thread addf or2.3 servo-thread addf or2.4 servo-thread addf or2.5 servo-thread addf or2.6 servo-thread addf or2.7 servo-thread addf or2.8 servo-thread addf or2.9 servo-thread addf toggle.0 servo-thread addf toggle2nist.0 servo-thread addf ff1 servo-thread addf ff2 servo-thread addf near.0 servo-thread addf near.1 servo-thread addf scale.sp servo-thread addf scale.jog servo-thread addf scale-fo servo-thread addf scale-ro servo-thread addf scale-so servo-thread addf scale-maxa servo-thread addf abs.spindle servo-thread addf lowpass.spindle servo-thread addf limit1.0 servo-thread addf limit1.1 servo-thread addf limit2.0 servo-thread addf mux2.0 servo-thread addf mux2.1 servo-thread addf mux2.2 servo-thread ###################################################################################### ###################################################################################### ###################################################################################### #################################### AXIS HAL ######################################## ###################################################################################### ###################################################################################### ###################################################################################### #########################################--- "ESTOP-OUT" ---############## # "Estop output logic" ### # "Enables 10CR to enable power up" ### # "Drives DC Interlock relay" ### # --- "ESTOP-OUT" ---##################################################### net estop-out hm2_5i25.0.7i77.0.0.output-00 net machine-is-enabled hm2_5i25.0.7i77.0.0.output-01 ################################################################### # "Overrides" # ################################################################### # "Read analog inputs from the override knobs. Full scale will be"# # "approximately 24v. Scale the input accordingly. 1.0 = 100%" # # # # "Scale up the raw values 100x so that when converted to" # # "integers we have good resolution." # # "The results will be between 0 and 2400." # ################################################################### ################"--- Feed Override ---"################## # Convert from float to S32 # ######################################################### # "Read in analog input and send to halui.feed-override" # "Enable direct count input" net scale_ovr => scale-fo.gain scale-ro.gain scale-so.gain sets scale_ovr 100.0 #100 net fo-ena halui.feed-override.count-enable halui.feed-override.direct-value sets fo-ena 1 # "Scale down the value to a percentage" net scf-scale => halui.feed-override.scale sets scf-scale 0.000852 net scf-raw scale-fo.in <= hm2_5i25.0.7i77.0.0.analogin0 net scf-raw-adj cnvf.in <= scale-fo.out net scf-s halui.feed-override.counts <= cnvf.out ################"--- Rapid Override ---"################# # Convert from float to S32 # ######################################################### # "Read in analog input and send to halui.rapid-override" # "Enable direct count input" net ro-ena halui.rapid-override.count-enable halui.rapid-override.direct-value sets ro-ena 1 # "Scale down the value to a percentage" net scr-scale => halui.rapid-override.scale sets scr-scale 0.00044 net scr-raw scale-ro.in <= hm2_5i25.0.7i77.0.0.analogin1 net scr-raw-adj cnvr.in <= scale-ro.out net scr-s halui.rapid-override.counts <= cnvr.out ###############"--- Spindle Override ---"################ # Convert from float to S32 # ######################################################### # "Read in analog input and send to halui.spindle-override" # "Enable direct count input" net so-ena halui.spindle-override.count-enable halui.spindle-override.direct-value sets so-ena 1 # "Scale down the value to a percentage" net scs-scale => halui.spindle-override.scale sets scs-scale 0.0005 #0.0005 # "Add an offest so that we have a minimum override of 30%" #net scs-offset => scale-so.offset #sets scs-offset 100 net scs-raw scale-so.in <= hm2_5i25.0.7i77.0.0.analogin2 net scs-raw-adj cnvs.in <= scale-so.out net scs-s halui.spindle-override.counts <= cnvs.out ######################################################### # "External Pause/Resume Section" [Stop] # ######################################################### setp debounce.0.delay 20 net pause-resume-btn and2.0.in0 and2.1.in0 <= hm2_5i25.0.7i77.0.0.input-17-not net pause-on toggle2nist.0.is-on and2.0.in1 and2.3.in1 <= halui.program.is-paused net run-on and2.1.in1 <= halui.program.is-running net pause-sig or2.0.in0 <= and2.0.out net resume-sig or2.0.in1 <= and2.1.out net toggle-ok toggle.0.in <= or2.0.out net togglesig toggle2nist.0.in <= toggle.0.out net toggleon halui.program.pause <= toggle2nist.0.on net toggleoff halui.program.resume <= toggle2nist.0.off ######################################################### # "External Run/Step Section" [Start] # ######################################################### net run-step-btn and2.2.in0 and2.3.in0 <= hm2_5i25.0.7i77.0.0.input-16 net idle-on and2.2.in1 <= halui.program.is-idle net run-sig halui.mode.auto halui.program.run <= and2.2.out net step-sig halui.program.step <= and2.3.out ##################################################################################### # "This is how The External Step/Pause buttons function:" # ##################################################################################### # "Pressing Run/Step will begin executing a program. # # Pressing Hold/Resume while a program is running will pause the program. # # Pressing Run/Step while a program is paused will single step the program. # # Pressing Hold/Resume while a program is paused will return it to normal run mode."# ##################################################################################### ####################################################################### # "Manual Panel/Joystick Jog signals" # ####################################################################### # "JOG X" # ####################################################################### net jog-x-pos hm2_5i25.0.7i77.0.0.input-06 or2.4.in0 net jog-x-pos-p hm2_5i25.0.7i77.0.0.input-20 or2.4.in1 net or-out0 or2.4.out halui.jog.0.plus net jog-x-neg hm2_5i25.0.7i77.0.0.input-07 or2.5.in0 net jog-x-neg-p hm2_5i25.0.7i77.0.0.input-21 or2.5.in1 net or-out1 or2.5.out halui.jog.0.minus ####################################################################### # "JOG Y" # ####################################################################### net jog-y-pos hm2_5i25.0.7i77.0.0.input-08 or2.6.in0 net jog-y-pos-p hm2_5i25.0.7i77.0.0.input-19 or2.6.in1 net or-out2 or2.6.out halui.jog.1.plus net jog-y-neg hm2_5i25.0.7i77.0.0.input-09 or2.7.in0 net jog-y-neg-p hm2_5i25.0.7i77.0.0.input-18 or2.7.in1 net or-out3 or2.7.out halui.jog.1.minus ####################################################################### # "JOG Z" # ####################################################################### net jog-z-pos hm2_5i25.0.7i77.0.0.input-10 or2.8.in0 net jog-z-pos-p hm2_5i25.0.7i77.0.0.input-22 or2.8.in1 net or-out4 or2.8.out halui.jog.2.plus net jog-z-neg hm2_5i25.0.7i77.0.0.input-11 or2.9.in0 net jog-z-neg-p hm2_5i25.0.7i77.0.0.input-23 or2.9.in1 net or-out5 or2.9.out halui.jog.2.minus # "Using or2 with two inputs" #net signal-a input-a => or2.0.in0 #net signal-b input-b => or2.0.in1 #net or-out or2.0.out => input # "Joystick switches (currently unused)" #net jog-continuous <= hm2_5i25.0.7i77.0.0.input-12 ############################################################# # "JOG Rates - Select the limited rate when we jog z minus" # ############################################################# setp limit1.0.max 20 net jog-speed => limit1.0.in => mux2.0.in0 net jog-speed-lim <= limit1.0.out => mux2.0.in1 net jog-z-neg => mux2.0.sel net jog-speed-sel <= mux2.0.out => halui.jog-speed ############################################################### # "Home switch inputs" # ############################################################### net home-x <= hm2_5i25.0.7i77.0.0.input-13 net home-y <= hm2_5i25.0.7i77.0.0.input-14 net home-z <= hm2_5i25.0.7i77.0.0.input-15 ######################################################### # "X AXIS" # ######################################################### setp pid.x.Pgain [AXIS_0]P setp pid.x.Igain [AXIS_0]I setp pid.x.Dgain [AXIS_0]D setp pid.x.bias [AXIS_0]BIAS setp pid.x.FF0 [AXIS_0]FF0 setp pid.x.FF1 [AXIS_0]FF1 setp pid.x.FF2 [AXIS_0]FF2 setp pid.x.deadband [AXIS_0]DEADBAND setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT setp pid.x.error-previous-target true setp pid.x.maxerror .0005 net x-index-enable <=> pid.x.index-enable net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-vel-cmd => pid.x.command-deriv net x-pos-fb => pid.x.feedback net x-output => pid.x.output ############################################# # ---"X AXIS PWM Generator signals/setup"---# ############################################# setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [AXIS_0]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout0-minlim [AXIS_0]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [AXIS_0]OUTPUT_MAX_LIMIT net x-output => hm2_5i25.0.7i77.0.1.analogout0 net x-pos-cmd axis.0.motor-pos-cmd net x-enable axis.0.amp-enable-out ######################################## # "X AXIS enable _all_ sserial pwmgens"# ######################################## net x-enable hm2_5i25.0.7i77.0.1.analogena ################################################ # ---"X AXIS Encoder feedback signals/setup"---# ################################################ setp hm2_5i25.0.encoder.00.counter-mode 0 setp hm2_5i25.0.encoder.00.filter 1 setp hm2_5i25.0.encoder.00.index-invert 0 setp hm2_5i25.0.encoder.00.index-mask 0 setp hm2_5i25.0.encoder.00.index-mask-invert 0 setp hm2_5i25.0.encoder.00.scale [AXIS_0]ENCODER_SCALE net x-pos-fb <= hm2_5i25.0.encoder.00.position net x-vel-fb <= hm2_5i25.0.encoder.00.velocity net x-pos-fb => axis.0.motor-pos-fb net x-index-enable axis.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts ################################################### # ---"X AXIS home / limit switch signals"--- # ################################################### net home-x => axis.0.home-sw-in net x-neg-limit => axis.0.neg-lim-sw-in net x-pos-limit => axis.0.pos-lim-sw-in ######################################################### # "Y AXIS" # ######################################################### setp pid.y.Pgain [AXIS_1]P setp pid.y.Igain [AXIS_1]I setp pid.y.Dgain [AXIS_1]D setp pid.y.bias [AXIS_1]BIAS setp pid.y.FF0 [AXIS_1]FF0 setp pid.y.FF1 [AXIS_1]FF1 setp pid.y.FF2 [AXIS_1]FF2 setp pid.y.deadband [AXIS_1]DEADBAND setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT setp pid.y.error-previous-target true setp pid.y.maxerror .0005 net y-index-enable <=> pid.y.index-enable net y-enable => pid.y.enable net y-pos-cmd => pid.y.command net y-vel-cmd => pid.y.command-deriv net y-pos-fb => pid.y.feedback net y-output => pid.y.output ############################################# # ---"Y AXIS PWM Generator signals/setup"---# ############################################# setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [AXIS_1]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout1-minlim [AXIS_1]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [AXIS_1]OUTPUT_MAX_LIMIT net y-output => hm2_5i25.0.7i77.0.1.analogout1 net y-pos-cmd axis.1.motor-pos-cmd net y-enable axis.1.amp-enable-out ############################################### # ---"Y AXIS Encoder feedback signals/setup"---# ############################################### setp hm2_5i25.0.encoder.01.counter-mode 0 setp hm2_5i25.0.encoder.01.filter 1 setp hm2_5i25.0.encoder.01.index-invert 0 setp hm2_5i25.0.encoder.01.index-mask 0 setp hm2_5i25.0.encoder.01.index-mask-invert 0 setp hm2_5i25.0.encoder.01.scale [AXIS_1]ENCODER_SCALE net y-pos-fb <= hm2_5i25.0.encoder.01.position net y-vel-fb <= hm2_5i25.0.encoder.01.velocity net y-pos-fb => axis.1.motor-pos-fb net y-index-enable axis.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable net y-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts ################################################### # ---"Y AXIS home / limit switch signals"--- # ################################################### net home-y => axis.1.home-sw-in net y-neg-limit => axis.1.neg-lim-sw-in net y-pos-limit => axis.1.pos-lim-sw-in ######################################################### # "Z AXIS" # ######################################################### setp pid.z.Pgain [AXIS_2]P setp pid.z.Igain [AXIS_2]I setp pid.z.Dgain [AXIS_2]D setp pid.z.bias [AXIS_2]BIAS setp pid.z.FF0 [AXIS_2]FF0 setp pid.z.FF1 [AXIS_2]FF1 setp pid.z.FF2 [AXIS_2]FF2 setp pid.z.deadband [AXIS_2]DEADBAND setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT setp pid.z.error-previous-target true setp pid.z.maxerror .0005 net z-index-enable <=> pid.z.index-enable net z-enable => pid.z.enable net z-pos-cmd => pid.z.command net z-vel-cmd => pid.z.command-deriv net z-pos-fb => pid.z.feedback net z-output => pid.z.output ############################################# # ---"Z AXIS PWM Generator signals/setup"---# ############################################# setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [AXIS_2]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout2-minlim [AXIS_2]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [AXIS_2]OUTPUT_MAX_LIMIT net z-output => hm2_5i25.0.7i77.0.1.analogout2 net z-pos-cmd axis.2.motor-pos-cmd net z-enable axis.2.amp-enable-out ################################################ # ---"Z AXIS Encoder feedback signals/setup"---# ################################################ setp hm2_5i25.0.encoder.02.counter-mode 0 setp hm2_5i25.0.encoder.02.filter 1 setp hm2_5i25.0.encoder.02.index-invert 0 setp hm2_5i25.0.encoder.02.index-mask 0 setp hm2_5i25.0.encoder.02.index-mask-invert 0 setp hm2_5i25.0.encoder.02.scale [AXIS_2]ENCODER_SCALE net z-pos-fb <= hm2_5i25.0.encoder.02.position net z-vel-fb <= hm2_5i25.0.encoder.02.velocity net z-pos-fb => axis.2.motor-pos-fb net z-index-enable axis.2.index-enable <=> hm2_5i25.0.encoder.02.index-enable net z-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts ################################################### # ---"Z AXIS home / limit switch signals"--- # ################################################### net home-z => axis.2.home-sw-in net z-neg-limit => axis.2.neg-lim-sw-in net z-pos-limit => axis.2.pos-lim-sw-in ######################################################### # "SPINDLE" # ######################################################### setp pid.s.Pgain [SPINDLE_9]P setp pid.s.Igain [SPINDLE_9]I setp pid.s.Dgain [SPINDLE_9]D setp pid.s.bias [SPINDLE_9]BIAS setp pid.s.FF0 [SPINDLE_9]FF0 setp pid.s.FF1 [SPINDLE_9]FF1 setp pid.s.FF2 [SPINDLE_9]FF2 setp pid.s.deadband [SPINDLE_9]DEADBAND setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT setp pid.s.error-previous-target true setp pid.s.maxerror .0005 net spindle-index-enable <=> pid.s.index-enable net spindle-enable => pid.s.enable net spindle-vel-cmd-rpm => pid.s.command net spindle-vel-fb-rpm => pid.s.feedback net spindle-output <= pid.s.output ################################################ # ---"SPINDLE control signals"--- # ################################################ net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs net spindle-vel-cmd-rpm <= motion.spindle-speed-out net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs #net spindle-enable <= motion.spindle-on #net spindle-cw <= motion.spindle-forward #net spindle-ccw <= motion.spindle-reverse net spindle-brake <= motion.spindle-brake net spindle-revs => motion.spindle-revs net spindle-at-speed => motion.spindle-at-speed net spindle-vel-fb-rps => motion.spindle-speed-in net spindle-index-enable <=> motion.spindle-index-enable ################################################# # ---"SPINDLE at speed signals"--- # ################################################# sets spindle-at-speed true ######################################################### # "MISC SIGNALS" # ######################################################### net joint-select-a halui.joint.0.select net x-is-homed halui.joint.0.is-homed net jog-x-analog halui.jog.0.analog net joint-select-b halui.joint.1.select net y-is-homed halui.joint.1.is-homed net jog-y-analog halui.jog.1.analog net joint-select-c halui.joint.2.select net z-is-homed halui.joint.2.is-homed net jog-z-analog halui.jog.2.analog net jog-selected-pos halui.jog.selected.plus net jog-selected-neg halui.jog.selected.minus net spindle-manual-cw halui.spindle.forward net spindle-manual-ccw halui.spindle.reverse net spindle-manual-stop halui.spindle.stop net machine-is-on halui.machine.is-on net MDI-mode halui.mode.is-mdi ########################### # ---"coolant signals"---# ########################### net coolant-mist <= iocontrol.0.coolant-mist net coolant-flood <= iocontrol.0.coolant-flood ############################################################## # "Probe input & output" # ############################################################## #net probe-in <= hm2_5i25.0.7i77.0.0.input-23 => or2.3.in0 #net toolset-in <= hm2_5i25.0.7i77.0.0.input-24 => or2.3.in1 #net probe-signal <= or2.3.out => motion.probe-input #"Output a short pulse to the probe LED/Beeper on contact" #setp os5.falling FALSE #setp os5.rising TRUE #newsig os5Time float #net os5Time => os5.width #sets os5Time 0.02 #net probe-signal => os5.in #net probe-led <= os5.out => hm2_5i25.0.7i77.0.0.output-10 net probe-in => motion.probe-input ################################## # ---"motion control signals"---# ################################## net in-position <= motion.in-position net machine-is-enabled <= motion.motion-enabled ########################## # ---"estop signals"--- # ########################## net estop-out <= iocontrol.0.user-enable-out net estop-out => iocontrol.0.emc-enable-in ######################################################### # "Manual Tool Change" # ######################################################### loadusr -W hal_manualtoolchange net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared ######################################################### # "SHARED JOGWHEEL MPG" # ######################################################### net joint-selected-count <= hm2_5i25.0.encoder.03.count ######################################### ######### "for axis x MPG" ######### ######################################### setp axis.0.jog-vel-mode 0 net selected-jog-incr => axis.0.jog-scale #net jog-ena-x => axis.0.jog-enable net joint-selected-count => axis.0.jog-counts ######################################### ######### "for axis y MPG" ######### ######################################### setp axis.1.jog-vel-mode 0 net selected-jog-incr => axis.1.jog-scale #net jog-ena-y => axis.1.jog-enable net joint-selected-count => axis.1.jog-counts ######################################### ######### "for axis z MPG" ######### ######################################### setp axis.2.jog-vel-mode 0 # "Limit Z motion, should be about 20 FPM" setp limit1.1.max [MPG]Z_MINUS_LIMIT net selected-jog-incr => limit1.1.in net selected-jog-incr-z <= limit1.1.out => axis.2.jog-scale #net jog-ena-z => axis.2.jog-enable net joint-selected-count => axis.2.jog-counts # "Scale the jog rate (FPM) to an increment per Handwheel count" setp scale.jog.gain [MPG]HAND_WHEEL_SCALE net jog-speed => scale.jog.in ######################################################### # "MPG JOG SELECTED" # ######################################################### net jog-ena-z hm2_5i25.0.7i77.0.0.input-25 => axis.2.jog-enable net jog-ena-z-not hm2_5i25.0.7i77.0.0.input-25-not => and2.11.in0 net jog-ena-x hm2_5i25.0.7i77.0.0.input-24 => axis.0.jog-enable net jog-ena-x-not hm2_5i25.0.7i77.0.0.input-24-not => and2.11.in1 net jog-ena-y and2.11.out => axis.1.jog-enable sets selected-jog-incr .000001 sets jog-speed 100 ######################################################### # "POST GUI FILE BERTHA Jog signals" # ######################################################### #net jog-speed <= gscreen.jog-spd-out #net jog-inc <= screen.jog-inc-out #net jog-ena-x <= gscreen.jog-enable-x-out #net jog-ena-y <= gscreen.jog-enable-y-out #net jog-ena-z <= gscreen.jog-enable-z-out
ini file
# Generated by PNCconf at Fri Jan 15 18:07:07 2016 # If you make changes to this file, they will be # overwritten when you run PNCconf again [EMC] MACHINE = bridgeport DEBUG = 0 [DISPLAY] #DISPLAY = gmoccapy DISPLAY = axis EMBED_TAB_NAME=Huanyang VFD #EMBED_TAB_LOCATION=ntb_user_tabs EMBED_TAB_COMMAND=halcmd loadusr -Wn vfd gladevcp -c vfd -x {XID} -u handler.py huanyang.glade EMBED_TAB_NAME=Probe Screen #EMBED_TAB_LOCATION=ntb_user_tabs EMBED_TAB_COMMAND=halcmd loadusr -Wn probe_screen gladevcp -c probe_screen -u python/probe_screen.py -x {XID} probe_icons/probe_screen.glade #******** required 'NativeCAM' items:******************************************** ## ncam.ui is required in this directory, relative or absolute GLADEVCP = -U --catalog=mill ncam.ui PROGRAM_PREFIX = ncam/scripts/ # NCAM_DIR ***'MUST'*** match the first dir of SUBROUTINE_PATHS NCAM_DIR = ncam #******************************************************************************** EDITOR = kate POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 2.000000 MAX_SPINDLE_OVERRIDE = 1.20000 MIN_SPINDLE_OVERRIDE = 0.050000 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 3 PROGRAM_PREFIX = /home/stacie/linuxcnc/nc_files INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in POSITION_FEEDBACK = ACTUAL DEFAULT_LINEAR_VELOCITY = 0.250000 MAX_LINEAR_VELOCITY = 2.0 MIN_LINEAR_VELOCITY = 0.010000 DEFAULT_ANGULAR_VELOCITY = 0.250000 MAX_ANGULAR_VELOCITY = 1.000000 MIN_ANGULAR_VELOCITY = 0.010000 EDITOR = gedit GEOMETRY = xyz [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] FEATURES=30 PARAMETER_FILE = linuxcnc.var #******** required 'NativeCAM' items will be created the first time*** # "NCAM_DIR must be specified" SUBROUTINE_PATH = ncam/lib/mill:ncam/lib/utilities:/home/stacie/linuxcnc/configs/bridgeport_axis/macros/ #********************************************************************* [TOOLSENSOR] # Control probe rapid feed (in machine units per minute) RAPID_SPEED = 100 [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 SERVO_PERIOD = 1000000 [HOSTMOT2] # **** This is for info only **** # DRIVER0=hm2_pci # BOARD0=5i25 [HAL] HALUI = halui HALFILE = bridgeport.hal HALFILE = custom.hal POSTGUI_HALFILE = custom_postgui.hal SHUTDOWN = shutdown.hal [HALUI] [TRAJ] AXES = 3 COORDINATES = X Y Z LINEAR_UNITS = inch ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 6.0 MAX_VELOCITY = 6.00 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl #******************** # Axis X #******************** [AXIS_0] TYPE = LINEAR HOME = 0.0 FERROR = 1.003 MIN_FERROR = 1.003 MAX_VELOCITY = 3.10 MAX_ACCELERATION = 5.0 P = 150 I = 0 D = 0 FF0 = 0 FF1 = 2.74 FF2 = 0.003 BIAS = 0 DEADBAND = 0.00009 MAX_OUTPUT = 10 ENCODER_SCALE = -50800 OUTPUT_SCALE = 10 OUTPUT_MIN_LIMIT = -10 OUTPUT_MAX_LIMIT = 10 MIN_LIMIT = -17.755 MAX_LIMIT = 0.04 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0.5 HOME_LATCH_VEL = 0.017 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO HOME_SEQUENCE = 1 #******************** # Axis Y #******************** [AXIS_1] TYPE = LINEAR HOME = 0.0 FERROR = 0.003 MIN_FERROR = 0.003 MAX_VELOCITY = 3.10 MAX_ACCELERATION = 5.0 P = 150 I = 0 D = 0 FF0 = 0 FF1 = 2.74 FF2 = 0.003 BIAS = 0 DEADBAND = 0.000059 MAX_OUTPUT = 10 ENCODER_SCALE = -50800 OUTPUT_SCALE = 10 OUTPUT_MIN_LIMIT = -10 OUTPUT_MAX_LIMIT = 10 MIN_LIMIT = -11.373 MAX_LIMIT = 0.303 HOME_OFFSET = 0.000000 HOME_SEARCH_VEL = 0.500000 HOME_LATCH_VEL = 0.016667 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO HOME_SEQUENCE = 2 #******************** # Axis Z #******************** [AXIS_2] TYPE = LINEAR HOME = 0.0 FERROR = 0.003 MIN_FERROR = 0.003 MAX_VELOCITY = 2.5 MAX_ACCELERATION = 5.0 P = 150 I = 0 D = 0 FF0 = 0 FF1 = 2.74 FF2 = 0.003 BIAS = 0 DEADBAND = 0.000059 MAX_OUTPUT = 10 ENCODER_SCALE = -50800 OUTPUT_SCALE = 10 OUTPUT_MIN_LIMIT = -10 OUTPUT_MAX_LIMIT = 10 MIN_LIMIT = -4.465 MAX_LIMIT = 0.069 HOME_OFFSET = 0.000000 HOME_SEARCH_VEL = 0.50000 HOME_LATCH_VEL = 0.016667 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO HOME_SEQUENCE = 0 #******************** # Spindle #******************** [SPINDLE_9] P = 0 I = 0 D = 0 FF0 = 1 FF1 = 0 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 10 #******************** # Handwheel #******************** [MPG] HAND_WHEEL_SCALE = 0.00000016 Z_MINUS_LIMIT = 0.000008
8 years 1 month ago #117242 by PCW
If you are communicating with the 7I77 the problem is _not_ firmware
At forst glance at least these statements should be removed from the hal file:
setp pid.N.maxerror .0005
where N is x,y,z
Moderators: PCW, jmelson
Time to create page: 0.305 seconds
