AMC servo drives pictures
  • Catch22
  • Catch22's Avatar Topic Author
  • Elite Member
  • Elite Member
07 Oct 2018 01:36 - 07 Oct 2018 16:23 #118509 by Catch22
AMC servo drives pictures was created by Catch22
I am trying to convert my 1987 cnc mill with the anilam crusader m control to Linuxcnc. I bought 3 advanced Motion Controls be25a20h drivers but I have no idea how to wire them, mostly because I don't understand the terms. Does anyone have a picture with the wires labeled by chance. My mill has the SEM brushed servo motors with the linear scales and the tachos,there are no encoders but I do have some, just not sure if it is worth installing them or not. Any help would be greatly appreciated.
Thanks Mike
Last edit: 07 Oct 2018 16:23 by Catch22.
07 Oct 2018 18:39 #118515 by PCW
Replied by PCW on topic AMC servo drives pictures
I cannot give an exact connection diagram because I don't know all of your hardware
but there are three basic analog servo interface "sections": ANALOG, ENABLE, ENCODER
ANALOG:
BE25A20H         7I77 TB5
4 +REF IN        4 AOUT0
5 -REF IN        3 GND
ENABLE:
Enable is a bit awkward since the BE25A20H has a disable (inhibit) line that must be grounded before LinuxCNC starts, the easiest way to do this is with a relay (this relay may in fact already exist in the old control) Another option instead of the relay is a strong pulldown resistor from the /inhibit pin to ground and then driving the pin hive via the 7I77s ENAble outputs. This requires tapping onto the drives +5V encode outpu to supply the pullup power.
Some drives can be modified to change the default inhibit polarity so it would be wise to determine this before starting in case the relay/pulldown resistor parts can be avoided
assuming inhibit must be grounded to disable the drive:
BE25A20H     Enable relay
9 /INHIBIT   NC relay contact 1
11 GND       NC relay contact 2
7I77 ENA0+   +24V
7I77 ENA0-   NC relay coil+
(24V common to NC relay coil -)
ENCODER
Depending on whether you have a TTL of differential interface scale you will connect
TTL Encoder  7I77 TB3
5V           6 +5V
A            1 QA0
B            4 QB0
Z            7 IDX0
GND          3 GND
(for TTL encoders, the 7I77s /QA0,/QB0,/IDX0 are left unconnected)
Diff. Encoder 7I77 TB3
5V            6 +5V
A             1 QA0
/A            2 /QA0
B             4 QB0
/B            5 /QB0
Z             7 IDX0
/Z            8 /IDX0
GND           3 GND
  • Catch22
  • Elite Member
  • Elite Member
08 Oct 2018 15:19 #118543 by Catch22
Replied by Catch22 on topic AMC servo drives pictures
Thank you very much PCW for taking the time to help me out, I will see if I can get things wired up and working.
Thanks Mike
15 Oct 2018 02:24 #118811 by JR1050
Replied by JR1050 on topic AMC servo drives pictures
BE drives are for brushless motors You would be better off with standard 25a20 brush drives. They have input for the tach. You can use the brushless drives with brush motors. All of the manuals are available from Amc website. You can also set a jumper in the drive to set the enable to on, I set them up this way and use a contractor to power my dc supply. Hitting estop cuts power to the machine. You might wanna look at the brushed drives.
15 Oct 2018 02:46 #118813 by OT-CNC
Replied by OT-CNC on topic AMC servo drives pictures
Any reason to not use the drives that came with the machine?
Just read in the linear encoders to linuxcnc. You'll get some dithering which can be annoying if you have excessive backlash but on my BP it's not an issue.
  • Catch22
  • Elite Member
  • Elite Member
15 Oct 2018 22:51 #118854 by Catch22
I already have the brushless drives.
16 Oct 2018 02:09 - 16 Oct 2018 02:14 #118858 by OT-CNC
Deleted duplicate post
Last edit: 16 Oct 2018 02:14 by OT-CNC. Reason: format, deleted duplicate post
16 Oct 2018 02:10 - 16 Oct 2018 02:12 #118859 by OT-CNC
The motors are brushed. Are you switching out the motors to BL type?
JR1050, was that a typo or are these drives compatible with brushed motors?? I didn't review the docs...
If the drives are still in the control box with the power supply etc working I would just connect the 7i77 to them. The stock drives will already be tuned and relatively quick to get going.
Last edit: 16 Oct 2018 02:12 by OT-CNC. Reason: format
16 Oct 2018 03:40 #118861 by JR1050
In the manual, there is a section on driving a brushed motor with a brushless drive. I have done it with amc drives , I have a huge dc motor on the z axis of my mill and it can easily pull 35 amps. Amc only make a brushless drive that handled that much current. It was a B something not a BE, it had the input for the tach.
All this being said, trying to run a motor in current mode with glass scales could be tricky, if you can use the tachs, at least you can close the velocity loop in the drive. If you have a rotary encoder, the drive will convert the signals into velocity feedback, I think ..... The 25a20 brushed drives are cheap on eBay and you will quickly recoup your costs by selling the BE drives. Curious, are the original drives functional?
  • Catch22
  • Elite Member
  • Elite Member
16 Oct 2018 21:07 #118905 by Catch22
The brushless drives have a negative tach in, is that not the same thing.
Moderators: PCW, jmelson
Time to create page: 0.177 seconds
