7i76e available input types vs mode
- Nitram
- Thank you received: 15
09 Nov 2018 15:00 #120332
by Nitram
7i76e available input types vs mode was created by Nitram
Hi Peter.
The 7i76e has 3 modes, i.e. 0 = I/O, 1 = I/O + analogue and 2 = I/O + analogue + encoders.
I use the 7i76e in mode 1 with 4 analogue inputs. I do not use any encoders on the board.
I have need for one more analogue input. If the board is being run in mode 1, does this open the 4 inputs on the other TB for analogue input as well? I.e. those that would otherwise have been used for encoder input in mode 2?
If not, is there any Mesa flash available to facilitate this?
Thanks,
Marty.
Thanks,
Marty.
- Thank you received: 5326
09 Nov 2018 16:15 #120334
Replied by PCW on topic 7i76e available input types vs mode
No, currently 4 analog inputs is the maximum
Its possible hardware wise but would require a new mode added to the 7I76 portion of the 7I76E
09 Nov 2018 17:28 #120337
Replied by andypugh on topic 7i76e available input types vs mode
One possibility if the analogue inputs do not need to be sampled quickly would be to multiplex the analogue inputs.
This would need to be done in hardware.
uk.rs-online.com/web/p/zener-diodes/1707984/
Is an example of something that might work.
linuxcnc.org/docs/devel/html/man/man9/demux.9.html
Could divert the values to different HAL pins. Then a simple counter to cycle through the two selection bits in both hardware and software.
09 Nov 2018 19:42 #120347
I do have a Delta-Sigma A-D hm2 module that can make a pretty decent 10 or so bit 1 KHz A-D from a LVDS FPGA input pair but it requires 3 I/O bits per A-D (1 out and the LVDS pair used as a comparator) and 2 Rs and a C per channel (so you could get 5 A-Ds from a 17 I/O 7I76E expansion channel)
- Nitram
09 Nov 2018 20:05 #120349
by Nitram
Replied by Nitram on topic 7i76e available input types vs mode
Hi Andy.
The purpose of using the extra analogue input was to get VFD frequency feedback (as pseudo motor speed feedback) to explore your Automatic spindle gear detection on my lathe.
Do you have any thoughts as to whether there is a better or easier way without an analogue input to monitor this parameter for this purpose?
Thanks,
Marty.
Thanks,
Marty.
09 Nov 2018 20:32 #120351
Can you control the VFD via Modbus?
- Nitram
09 Nov 2018 21:17 #120352
by Nitram
I have all the serial ports available on a 7i85 which is connected to the 7i76e and is only utilizing encoder inputs. So physically it is possible st that end. I'll have to check the drive is capable. I have a hy drive so will check.
Is much involved in setting up of the modbus? I'm afraid I know little about it...
- Thank you received: 1476
09 Nov 2018 21:37 #120353
Replied by Todd Zuercher on topic 7i76e available input types vs mode
It is simpler to connect directly to the PC via an inexpencive USB dongle. No one has ever written a Modbus driver for Mesa hardware. While theoretically possible, I'm told it would have to be written into the firmware for the FPGA or the Hostmot2 driver or both, and that is easier said than done. (I really have no idea and it is well beyond my capabilities.)
- Nitram
09 Nov 2018 21:55 #120356
by Nitram
09 Nov 2018 22:02 #120357
It's on my list. But not at the top.
Time to create page: 0.196 seconds
