Cannot Connect to 7i76E
- Torq_Shep
27 Nov 2018 03:36 #121436
by Torq_Shep
Replied by Torq_Shep on topic Cannot Connect to 7i76E
Wonderful... I can probably just redo the kernel on the current install or would you just do a full re-install and redo the kernel then?
- Thank you received: 5325
27 Nov 2018 03:37 - 27 Nov 2018 03:42 #121437
Replied by PCW on topic Cannot Connect to 7i76E
Does "ip a" show ipv6 disabled?
(Also while Todd is correct that a Preempt-RT kernel and the uspace version of LinuxCNC are
needed to run the 7I76E as a machine controller, you should be able to ping the card from any system)
Last edit: 27 Nov 2018 03:42 by PCW.
- Torq_Shep
27 Nov 2018 03:40 #121438
by Torq_Shep
Not sure. It isn't saying anything specifically about IPV6. Admittedly, I am not as good as I once was with the kernel. Been maintaining windows stuff at work for too long.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: enp4s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 78:45:c4:2f:2a:bf brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/24 brd 10.10.10.255 scope global enp4s0
3: wlp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 9c:2a:70:10:8d:99 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.117/24 brd 192.168.0.255 scope global dynamic wlp3s0
valid_lft 6091sec preferred_lft 6091secPlease Log in or Create an account to join the conversation.
27 Nov 2018 03:44 #121440
OK it now shows IV6 disabled (also NO-CARRIER, was the 7I76E off or disconnected?)
- Torq_Shep
27 Nov 2018 03:44 #121441
by Torq_Shep
I can redo it NBD. But yes need to figure out the pinging issue. I will grab my phone and try and get a picture of my jumpers for you. I think I am reading the diagrams right but who knows.
- Torq_Shep
27 Nov 2018 03:45 #121442
by Torq_Shep
During that one yes. But every other time it was on.
- Torq_Shep
27 Nov 2018 03:50 - 27 Nov 2018 03:57 #121444
by Torq_Shep
See the pictures attached. Maybe you can make out the jumpers. Photography is not my strong point.
And apparently this forum hates pictures =P
photos.app.goo.gl/VKgWwyvJ6FozaBWJ9
photos.app.goo.gl/K8oRiW8DjGxavxMR9
Last edit: 27 Nov 2018 03:57 by Torq_Shep.
- Thank you received: 7478
27 Nov 2018 06:59 #121457
Replied by tommylight on topic Cannot Connect to 7i76E
Network setup for mesa cards:
- left click on the network manager on the bottom right side where the clock and volume is.
- choose "edit connections"
- double click on the network you want to edit ( usually "wired connection X")
- click on the "IPv4 settings" tab
- choose "manual" on the "method" drop down menu
- click on "add"
- write the address as 10.10.10.2 up to 10.10.10.9 ( never 10.10.10.1 or 10.10.10.10 )
- netmask should be set as 24 or 255.255.255.0
- gateway should always be 10.10.10.1
- additional DNS servers should be 10.10.10.1
Save, close, left click on the network manager and click on the "wired connection", it should take about 3 seconds to reconnect. Now open a terminal and do Ping 10.10.10.10, you should get normal reply form the Mesa card. If you do not get a reply, double check your settings.
>>> If you want to use another connection or a wireless connection for internet, you have to set up everything as above, and ONLY after having internet working edit the wired connection going to Mesa card again as follows:
- network manager>edit connections>wired connection X>IPv4 settings> ROUTES > just click on the "use this connection only for resources on its network"> OK>save>network manager>reconnect to that network.
- click on "add"
The following user(s) said Thank You: Muftijaja
- Torq_Shep
05 Dec 2018 00:29 #121842
by Torq_Shep
My apologies for being away. Went out of town for the week and am just now getting back to this. Trying the exact settings above still did not work. 2 different linux computers, 3 different ethernet cords, and I went through my board and set every single jumper back to default (except w3).
Additionally I tried the 192.168.1.121 configuration (address 192.168.1.124, netmask 24, gateway 192.168.1.1, additional DNS 192.168.1.1) and nothing...
At this point I am wondering if my board is faulty because surely it should not be this hard.
05 Dec 2018 06:35 #121848
Open terminal, type "ifconfig -a"
Time to create page: 0.268 seconds
