Cannot Connect to 7i76E
- Thank you received: 5325
10 Dec 2018 23:38 - 10 Dec 2018 23:38 #122175
Replied by PCW on topic Cannot Connect to 7i76E
I received the card today and it had an error I've not seen before:
Bad 93C46 EEPROM, bad in such a way that every other word of data
was 0xFFFF. Very strange because this is a on chip failure (1/2 memory array failed?)
This caused the MAC address to start with 0xFF which is invalid for non-broadcast packets,
so ARP worked but ping/UDP did not.
Last edit: 10 Dec 2018 23:38 by PCW.
- Torq_Shep
12 Dec 2018 00:24 #122241
by Torq_Shep
Replied by Torq_Shep on topic Cannot Connect to 7i76E
Can it be repaired or do I need another one?
12 Dec 2018 00:34 #122242
Already repaired, will send back tommorow
The following user(s) said Thank You: joekline9
- Torq_Shep
15 Dec 2018 18:56 #122451
by Torq_Shep
Received it and now it is letting me ping it! I will start messing around with the configuration again today or tomorrow.
- Torq_Shep
22 Dec 2018 19:31 #122754
by Torq_Shep
It worked temporarily and it is now reacting in the same way it was before. Is there any way I could have the board wired up in a way that it is causing this failure?
22 Dec 2018 19:52 #122756
Are you sure its the same issue? that does seem pretty unlikely
I don't see anyway a wiring error could cause EEPROM issues
Is it possible you have a power supply problem?
- Torq_Shep
22 Dec 2018 20:20 #122757
by Torq_Shep
It is possible. After a couple of restarts it seems to be working again. I will have to go through my machine and check everything else out. Thank you for being patient with me!
Time to create page: 0.196 seconds
