Mill conversion with Mesa 7i96
10 Jan 2019 14:43 #123902 by PCW
Replied by PCW on topic Mill conversion with Mesa 7i96
In that case I think you can just drive the joint and axis jog pins in
parallel so jog always works regardless of free/telelop mode
10 Jan 2019 14:51 #123904 by dgarrett
Replied by dgarrett on topic Mill conversion with Mesa 7i96
axis jog pins in parallel so jog always works regardless of
free/telelop mode
For the master branch (2.8~pre):
To use an MPG in identity kins configurations where
there is a one-to-one correspondence of a joint number and
an axis letter, it may be convenient to connect the
corresponding hal pins. ....
Ref:
linuxcnc.org/docs/master/html/getting-st...se_generator_jogging
General update reference for using the master branch:
linuxcnc.org/docs/master/html/getting-st...dating-linuxcnc.html
  • Clive S
  • Platinum Member
  • Platinum Member
10 Jan 2019 16:23 #123908 by Clive S
Replied by Clive S on topic Mill conversion with Mesa 7i96
This part now is all working as I want it. Thanks
net pend-x <= ilowpass.mpgX.out
net pend-x => axis.x.jog-counts
net pend-x => joint.0.jog-counts
setp axis.x.jog-enable true
setp joint.0.jog-enable true
  • Clive S
  • Platinum Member
  • Platinum Member
11 Jan 2019 15:08 - 11 Jan 2019 15:10 #123976 by Clive S
For completeness I attach the working config files (with the help from the forum) using a Mesa7i96 with linuxcnc 2.7.14 updated to 2.8
To be used on a Warco Wm18 mill conversion. Using 3 homing sensors and 3 mpg's
Last edit: 11 Jan 2019 15:10 by Clive S.
29 Jan 2020 18:54 #156103 by COFHAL
Replied by COFHAL on topic Mill conversion with Mesa 7i96
For what reason cannot the P1 expansion port inputs be used to connect the MPG encoders?
29 Jan 2020 19:08 #156106 by PCW
You could use them but without a daughtercard, they are rather fragile (like a bare parallel port) so if you connect the pins to the wrong thing you will damage the card
The following user(s) said Thank You: COFHAL
  • Clive S
  • Platinum Member
  • Platinum Member
29 Jan 2020 19:09 - 29 Jan 2020 19:12 #156107 by Clive S
Last edit: 29 Jan 2020 19:12 by Clive S.
29 Jan 2020 20:49 #156112 by COFHAL
Thanks for your reply, could you publish a diagram of how the MPG connection would be, to the 7i96 card?
29 Jan 2020 21:33 #156117 by COFHAL
Could you publish a diagram of how the MPG connection would be, to the 7i96 card?
  • Clive S
  • Platinum Member
  • Platinum Member
29 Jan 2020 21:43 #156118 by Clive S
Have you looked at my config files above
Moderators: PCWjmelson
Time to create page: 0.287 seconds
