Choosing the right Mesa Boards?
- Thank you received: 7468
02 Mar 2019 13:56 #127501
7i76E has 2 more break out board connectors ( those connectors can be used for other stuff to, like 7i74 or anothe 7i76 or 7i77 or.... ).
You do not need anything else if you go with the 7i76E, it has everything needed and plenty of inputs and outputs, you might only need a 7i85 ( again check if this is the correct board for encoder feedback ) IF and only if you want to have the loop closed in Linuxcnc.
Replied by tommylight on topic Choosing the right Mesa Boards?
So it seems like if I were going to use a 7i85 for encoder feedback it would make the most sense to to go with a 7i92 rather than 7i76E beacuse the 7i92 supports two break out boards so if I understand correctly the 7i76E would still require a 7192, 5i25 or 6i25 to run the 7i85?
If thats so would a good option be 7i92 with 7i76 and 7i85?
I apologize for all the questions just want to make sure I do this right.
- raglanlittlejohn
- Thank you received: 9
02 Mar 2019 15:28 #127515
by raglanlittlejohn
Replied by raglanlittlejohn on topic Choosing the right Mesa Boards?
If you go to this link, it shows the firmware available, and how to load it, ( the supplier will probably load it for you if you request it). www.wiki.eusurplus.com/index.php?title=C...a_Interface#Firmware
www.mesanet.com/ has the manuals for each card. You should be able to work out what the cards are capable of with the manual and the pin allocation.
I've set up a test config for a lathe using 5i25/7i78 and 7i85S cards. I flashed the firmware to the 5i25, and had no problems. I think you will be very happy with the Mesa cards.
- Type_Zero_Design
06 Mar 2019 00:03 #127841
by Type_Zero_Design
Replied by Type_Zero_Design on topic Choosing the right Mesa Boards?
Tommy any chance you'd be interested in "renting" me a 7i76E if you have one. Laying around and I'll drop ship a new one to you when they are back in stock? Attempted to "connect" with you not sure if that will allow DM.
06 Mar 2019 01:36 #127846
I would gladly, but i do not have a 7i76E ! Installed them quite some time ago.
I do have:
5i25 x1
6i25 x2
7i77 x2
7i84 x2
7i74 x1
7i92 x1
7i73 x2
THCAD x1
Planing to use the 7i92/7i77/7i74/2x7i84/7i73 on a retrofit of a MAZAK Micro Slant lathe i own. It is fully functional, but i do not want to use it as is, when i know it is going to be much easier to use when done. No deadline to finish it, but i am tired of looking at it as a 3.5 tone paper weight. Just need some time.
Already installed:
5i25 x2
6i25 x1
7i92 x1
7i74 x2
7i70 x2
7i71 x2
7i77 x3
7i76E x1 plus 1 that someone else ordered
That might be a nice reference of how good and versatile they are. Never had a single issue, ever. And the tech support is by far the best and the fastest on the planet earth! PCW is extremely helpful even when i needed some fancy firmware. Filipe (if i am not mistaken ) at eusurplus is also very helpful and keeps the delivery on time, always.
I get all my Mesa boards from eusurplus.com, and always someone else orders them so my name is never on the order. Did you try there ? They ship in 2 to 3 days from Portugal to Austria or Germany and from there it takes x days depending on my friends schedule.
From my point of view, when i know i have someone that could help when doing retrofits and make a tailored firmware, that is the biggest reward i can get as i am sure i can successfully finish whatever i have started.
I do have:
5i25 x1
6i25 x2
7i77 x2
7i84 x2
7i74 x1
7i92 x1
7i73 x2
THCAD x1
Already installed:
5i25 x2
6i25 x1
7i92 x1
7i74 x2
7i70 x2
7i71 x2
7i77 x3
- Type_Zero_Design
06 Mar 2019 02:30 - 06 Mar 2019 02:31 #127853
by Type_Zero_Design
Tommy, that's pretty impressive, do you do retrofits for a living? The lathe sounds like a good project , that's allot of boards! I feel like im missing something on mine with only two boards haha.
I have not looked into them, im in the US will they ship here? Anyhow im headed to their page to do some more research. Thanks for the info!
Last edit: 06 Mar 2019 02:31 by Type_Zero_Design.
- Type_Zero_Design
06 Mar 2019 05:09 #127860
by Type_Zero_Design
As Im doing more research and looking at how I would like to handle all of the wiring in this machine ive been looking at a few other options. (its amazing how many different options of combinations of boards there are available)
I would like to do Ethernet and this is what I was thinking at the moment.
7i92 (Ethernet FgPGA)
7i76 (Servo control step/dir)
7i85 (encoder Inputs)
7i85 (general Inputs relay switching Outputs)
7i85 (in control panel for controller inputs with only single cable to run to electrical cabinet)
Goal to have the cleanest wiring with the least bulk.
Not sure if this makes sense or not?
- Thank you received: 4652
06 Mar 2019 15:24 #127893
7i76E might be neater than 7i92+7i76.
Three 7i85 doesn't necessarily make sense. The 7i76 (or 7i76E) has one smart-serial port and the 7i85 has another. So look at the serial daughter cards for "stronger" IO that can switch relays etc directly.
store.mesanet.com/index.php?route=product/category&path=83_88
A 7i73 might be a good choice to put in the control panel, that is what it is meant for.
Replied by andypugh on topic Choosing the right Mesa Boards?
06 Mar 2019 23:06 #127922
Yes and no, meaning i do some for living and some for fun, but somehow i always get paid in parts or stuff even when i do it for fun !
In US you have another option, mesaus.com , that is JT online shop.
- Type_Zero_Design
07 Mar 2019 04:17 #127946
by Type_Zero_Design
Andy,
I had a typo there. I intended to put 7i85 for the encoders, and then to 7i84s
I'll check out the 7i73. They need some kind of quick reference guide for all these options! Haha
- pl7i92
- Thank you received: 358
07 Mar 2019 13:43 #127974
by pl7i92
Replied by pl7i92 on topic Choosing the right Mesa Boards?
choosing one is the one Side getting it anothere and Needing it also
You may only need less to get your things going then a Mesacard
consider the 1205 12Programmable outputs and 5 inputs to your need at less then 10USD
