7i76e was working, now CR1 LED does not go off
03 Apr 2019 20:58 - 03 Apr 2019 21:01 #130234 by PCW
Its what I would expect...
Why are you attempting to write the fallback configuration?
( This should really never need to be done and you don't want to
write a standard config to the fallback area either )
If you want to update the firmware, the command would be:
mesaflash --device 7i76e --write 7i76e_7i76x1D.bit
then a power cycle or
mesaflash --device 7i76e --reload
Last edit: 03 Apr 2019 21:01 by PCW.
03 Apr 2019 21:22 #130236 by macla
Because I clearly didn't understood when to use the fallback region and therefore followed the guide I linked to earlier - This guide said "When we try to flash a new bitfile onto the board we first try it in the fallback region. Let's flash the new 5i25_7i76_7i85s.bit bitfile and try if it works." This is apparently NOT the way to do it.
Anyway - it worked! The board now initializes correctly and CR1 goes off when I start up Linuxcnc.
Thanx alot!
Moderators: PCW, jmelson
Time to create page: 0.478 seconds
