7i76e Configuration Tool
11 May 2019 14:15 #133449 by BigJohnT
Replied by BigJohnT on topic 7i76e Configuration Tool
I verified the dependencies needed for a fresh install and updated the install instructions. Thanks for that feedback.
JT
The following user(s) said Thank You: AgentWD40
  • AgentWD40
  • AgentWD40's Avatar Topic Author
  • Platinum Member
  • Platinum Member
11 May 2019 14:21 - 11 May 2019 14:22 #133451 by AgentWD40
Replied by AgentWD40 on topic 7i76e Configuration Tool
I'll see about adding to it now that I know someone is using it.
Ha, well, uh, as of yesterday I decided to use the 7i96 instead. I will be exploring your 7i96 tool.
Last edit: 11 May 2019 14:22 by AgentWD40.
  • Type_Zero_Design
  • Premium Member
  • Premium Member
12 May 2019 03:53 #133501 by Type_Zero_Design
Replied by Type_Zero_Design on topic 7i76e Configuration Tool
John,
Just downloaded the 7i76e Config Tool, was able to get it up and going. Looks really nice!
But when I drop in the IP Address and attempt to read I get this....
tc225@TC225:~$ 7i76e
File "/home/tc225/.local/lib/python3.5/site-packages/m7i76e/7i76e.py", line 178, in cardRead
card.readCard(self)
File "/home/tc225/.local/lib/python3.5/site-packages/m7i76e/card.py", line 7, in readCard
stderr=subprocess.PIPE, universal_newlines=True)
File "/usr/lib/python3.5/subprocess.py", line 383, in run
with Popen(*popenargs, **kwargs) as process:
File "/usr/lib/python3.5/subprocess.py", line 676, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.5/subprocess.py", line 1282, in _execute_child
raise child_exception_type(errno_num, err_msg)
FileNotFoundError: [Errno 2] No such file or directory: './mesaflash64'
Aborted
tc225@TC225:~$
Any Thoughts?
12 May 2019 12:34 #133555 by BigJohnT
My MANIFEST.in file was missing an include, it has been fixed. Use the upgrade line from the docs to upgrade the install.
JT
  • Type_Zero_Design
  • Premium Member
  • Premium Member
12 May 2019 18:32 #133587 by Type_Zero_Design
John,
Ran the upgrade from the docs. it completed and said it installed. Re opened added the IP and I believe same results:
card.readCard(self)
Aborted
12 May 2019 19:09 #133588 by BigJohnT
I can see it in .local/lib/python3.5/site-packages/m7i76e on my test machine, but it needs to be in .local/bin. I'll have to work on the setup again and figure that out. I need to switch that hard drive to a different PC with dual NIC's so I can test it out with a card attached. That's what happens sometimes when you develop software and stuff is already there from another project.
JT
  • Type_Zero_Design
  • Premium Member
  • Premium Member
12 May 2019 19:50 #133591 by Type_Zero_Design
No worries,
will report back once the changes are made!
12 May 2019 22:20 #133604 by BigJohnT
Ok, I got the magic concoction needed to copy the mesaflash files to .local/bin and just tested it on a fresh install. Now I need to install LinuxCNC on that PC and test some other stuff.
So use the upgrade line again and it should work for you... I think.
JT
  • Type_Zero_Design
  • Premium Member
  • Premium Member
18 May 2019 03:40 #134097 by Type_Zero_Design
John. Missed your update here. Just tried the update, still running into the same issue for some reason.
21 May 2019 12:38 #134472 by BigJohnT
Opps I found that bug and squashed it I think. Update again and try.
JT
Moderators: PCW, jmelson
Time to create page: 0.475 seconds
