Wiring 7i96 and THCAD
- AgentWD40
- Thank you received: 96
30 May 2019 17:19 #135431
by AgentWD40
Replied by AgentWD40 on topic Wiring 7i96 and THCAD
That did it! We're in business.
Thank you, Peter!
Thank you, Peter!
- AgentWD40
15 Jan 2020 22:08 #154993
by AgentWD40
Does it matter at all what the input mode is set to on the index signal, jumper W4?
This is why I suggested setting the B encoder input to TTL mode (so it has a defined state when left unconnected)
but using differential mode on the A encoder input (since this mode has the best noise immunity)
- Thank you received: 5337
16 Jan 2020 14:32 #155033
Replied by PCW on topic Wiring 7i96 and THCAD
No, because index is not used ( The index input is a no-op unless the index enable pin is true )
The following user(s) said Thank You: AgentWD40
- xnaron
20 Aug 2020 11:21 - 20 Aug 2020 11:22 #178839
by xnaron
Replied by xnaron on topic Wiring 7i96 and THCAD
@AgentWD40 What are you using to create your diagrams. I have seen this style used before by others and always wondered if they are hand drawn in a drawing program or if there is some specific software designed to create them.
Last edit: 20 Aug 2020 11:22 by xnaron.
- AgentWD40
20 Aug 2020 11:43 #178841
by AgentWD40
Either ms paint or inkscape, depending on much punishment I want at the time.
Time to create page: 0.171 seconds
