Mesa Card Basics
- djdelorie
- Thank you received: 17
24 Dec 2025 17:21 #340469
by djdelorie
My first findings were that the HAL lag was significant and I had to limit "fast" probing to 6in/m or so, which made me wonder: I have the axis accel limited to reduce overshoot at the tool[3], but is there a way to override that when probing or homing so I can stop faster? Does homing use the joint accel limit instead of the axis accel? Can accel be changed by gcode or HAL?
My second findings were thus: if I probe towards and capture the result, then probe away at the same speed and capture *that* result, and average them, I get results that are more consistent and less dependent on probing speed. If this makes sense, one could drastically reducing probing time, but "probe slow enough" is just so much easier
Does it sound like I understand what's going on? Is there any value in pursuing the dual-probe-average method?
Is HAL lag impacted by the order in which stuff is listed in the config files? It would suck if I were calculating the probe signal just *before* reading the 7i76
[1] Aluminum extrusion CNC with 7i76 here, and sometimes the ATC actions vibrate the frame enough to trigger the toolsetter. Bad for normal operation, good for detecting failed tool releases
[2] I change the noise limits and/or disable the toolsetter based on the machine's XY position, as a "fix" for the above.
[3] the servos can stop on a dime, but the rest of the machine is limited by its strength and momentum.
[4] I really like the Mesa products, and really appreciate the work you folks have put into them
Replied by djdelorie on topic Mesa Card Basics
I pondered this truth at one point recently, and did some experiments. I wondered if the "signal lag" due to communications and HAL processing (I needed to add a noise remover[1] and mux[2] to my probe inputs, so I was at around 10ms of lag at the time, assuming each HAL component added at least one servo-loop of lag) was reducing precision here and causing the motion to continue past the actual probe point, and wondering how fast I could probe without destroying my toolsetter (testing delayed while toolsetter repaired) limited by this lag and deceleration limits.You would normally choose a latch velocity low enough that the 1 ms (max) sampling uncertainty causes a minimal position error when probing.
- Thank you received: 5324
24 Dec 2025 18:38 #340470
Replied by PCW on topic Mesa Card Basics
There should be no more than 1 ms in hal/LinuxCNC lag at a 1 ms servo thread rate.
if the probe signal goes through multiple hal components, they need to be addf'ed to the
servo thread in processing sequence or you will add additional pipeline delays.
That is, the sequence should be:
hardware read
process-0
process-1
process-2
motion
hardware write
hardware read
process-0
process-1
process-2
motion
hardware write
- djdelorie
24 Dec 2025 19:20 #340472
by djdelorie
That leads me to a follow-up HAL question (sorry for the thread drift). Can I add the same component twice? I mean, with different names, so I don't need one central "and2" with a dozen instances, I'd rather have each function/section add its own components as needed and in the right order.
If not, getting things in the right order across all components might be difficult.
Do the rest of my ponderings still apply, since I'm using dbounce and it delays the signal ?
Thanks!
Ah! I think I guessed that order was significant, I didn't realize it was official. Or at least "official".if the probe signal goes through multiple hal components, they need to be addf'ed to the
Thanks!
- Thank you received: 4654
22 Jan 2026 14:06 - 22 Jan 2026 14:08 #341701
Replied by andypugh on topic Mesa Card Basics
Yes, you can "addf" the and2 functions separately. This isn't true for all HAL components, some have a single read and/or write thread for all instances.
But for and2 you could have:
It is possible to retrospectively add functions in a position other than the end, if you really need to:
This seems to be less well documented than one might wish. Possibly it doesn't work properly. I think that positive numbers are position from the start and negative position from the end.
github.com/LinuxCNC/linuxcnc/blob/master...cmd_commands.cc#L318
loadrt and2 count=3
addf and2.2 servo-thread
{stuff}
addf and2.0 servo-thread
{stuff}
addf and2.1 servo-threadIt is possible to retrospectively add functions in a position other than the end, if you really need to:
addf and2.3 servo-thread 3This seems to be less well documented than one might wish. Possibly it doesn't work properly. I think that positive numbers are position from the start and negative position from the end.
Last edit: 22 Jan 2026 14:08 by andypugh.
- djdelorie
22 Jan 2026 17:10 #341709
by djdelorie
I guess my question was, can I do this:That way I can split my config into different files and not need to coordinate use of components centrally.
loadrt and2 name=probe_and count=2
addf probe_and.0 servo-thread
loadrt and2 name=estop_and count=4
addf estop_and.0 servo-threadPlease Log in or Create an account to join the conversation.
23 Jan 2026 19:17 #341780
You can't use names= and count= at the same time.
if using HAL_TWOPASS then they all need to use names=
In your example the correct syntax is:
addf probe_and servo-thread
addf estop_and servo-threadPlease Log in or Create an account to join the conversation.
- djdelorie
23 Jan 2026 19:34 #341783
by djdelorie
I think that's exactly what I was looking for, and wish I had known about it years ago
Now to see how well my configuration plays with it...
Thanks!
Thanks!
Time to create page: 0.262 seconds
