Need help to work with Mesa 5i25 with 7i77 boards basics
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Sep 2019 13:55 - 18 Sep 2019 13:57 #145506 by Dinuka_Shehan
My friend and I planned to retrofit a old cnc machine to upgrade to linux cnc.
We were choose mesa 5i25 and 7i77 as our boards.
This cnc mill is 3 axis and Axis are controlled with servo motors and has a umbrella tool changer.
How can we start this project.
Please be gentle and this is the first time with mesa boards with our selfves..
Your help is highly appreciated
Last edit: 18 Sep 2019 13:57 by Dinuka_Shehan.
18 Sep 2019 14:15 #145508 by bevins
I will assume you ordered the go kit which includes the cable and have installed linuxcnc successfully. This is the way I startup a system.
1. Determone if you want to use a seperate 5v power supply. I would suggest it. Select your jumpers and double check you set jumpers on the 5i25 to not send 5v out to the 7i77.
2. Set jumpers on 7i77 to receive external power.
3. install 5i25 in computer.
4. connect supplied cable from 5i25 to 7i77.
5. connect 5v to 7i77 on 5v terminal.
6. connect field power 12 or 24vdc to orange connector for field power making sure your polarity is correct.
7. power up power supplies.
Run pncconf.and go through and select and set what you need on your mill. encoders, limit switches, home switches, servo outs etc....
Start Linuxcnc and fix your mistakes in hal and ini files.
Close your estop input and set it in hal file.
Use HAL Calibration to check inputs are working.
That should keep you busy for a while.
The following user(s) said Thank You: Dinuka_Shehan
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
18 Sep 2019 14:23 #145509 by Dinuka_Shehan
If i get two of these boards separately.
How install firmware at first
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
18 Sep 2019 14:28 #145510 by Dinuka_Shehan
That should keep you busy for a whilequote]
Hope i will
18 Sep 2019 14:51 #145511 by PCW
If the 5I25 firmware is not correct you will need to run mesaflash and update the firmware. This must be done carefully as you can brick the 5I25 is you are not careful
Basically the first step is to check if the card has proper firmware installed
You can do this with the mesaflash command:
sudo mesaflash --device 5i25 --readhmid > pins.txt
and posting the pins.txt file here
18 Sep 2019 15:05 #145512 by bevins
Make your life easier. Buy the go kit.
  • Moderator
  • Moderator
18 Sep 2019 16:36 #145518 by tommylight
18 Sep 2019 16:54 #145522 by andypugh
There is a bit of an introduction to Mesa cards here: forum.linuxcnc.org/27-driver-boards/3714...a-card-basics#141789
Moderators: PCW, jmelson
Time to create page: 0.701 seconds
