Using pktuart with 7i80hd
- sneci
30 Sep 2019 20:21 #146762
by sneci
7i80 and uart test was created by sneci
I'm testing the uart component with a 7i80hd card. The setup runs without errors. An error message comes after the halcmd: start:
It seems to work with hm2_pci, but hm2_eth runs here in error.
(forum.linuxcnc.org/27-driver-boards/3711...o-linuxcnc2-8#141396)
Note: Check out Andy's change in mesa_uart.comp.
Some info:
system: Linux pcb 4.9.0-8-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.144-3.1 (2019-02-19) x86_64 GNU/Linux
firmware: hd_25_svstua4_12_4d.bit (forum.linuxcnc.org/27-driver-boards/3749...ile-with-uart#146551)
hal script:
I tried under linuxcnc-dev and from github with 2.9pre installation. The error is the same.
What do you suggest?
Thanks, sneci
#halcmd: hm2_eth: ERROR: used llio-> read in realtime task (addr = 0x6600)
# hm2_eth: This causes additional network packets which hurts performance
rtapi_app: caught signal 11 - dumping coreIt seems to work with hm2_pci, but hm2_eth runs here in error.
Some info:
hal script:
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config="num_uarts=1"
loadrt mesa_uart names="hm2_7i80.0.uart.0"
loadrt threads
addf hm2_7i80.0.read thread1
addf hm2_7i80.0.uart.0.receive thread1
addf hm2_7i80.0.uart.0.send thread1
addf hm2_7i80.0.write thread1
startI tried under linuxcnc-dev and from github with 2.9pre installation. The error is the same.
Thanks, sneci
- Thank you received: 5331
30 Sep 2019 21:51 #146768
Replied by PCW on topic 7i80 and uart test
I suspect the best solution would be to use the Packet UART instead
- sneci
30 Sep 2019 22:12 #146771
by sneci
Replied by sneci on topic 7i80 and uart test
thanks, I'll see what it is
I know the name, but I haven't worked on it yet.
- sneci
01 Oct 2019 17:30 - 01 Oct 2019 18:43 #146815
by sneci
Replied by sneci on topic Using pktuart with 7i80hd
I need some help.
I made a pin configuration with pktuart content. Editing and syntax checking is handy with Xilinx 13.4 WebPack. The code is fine, but I can't make a bit file. This project comes from mesanet.com 7i80.zip.
The bit file is created using the github hostmot2-firmware package. Downloading the generated bit file to the card comes with the same error as in the forum.linuxcnc.org/27-driver-boards/3749...25-bitfile-with-uart topic:
The problem comes from the environment. The PIN file received from Peter has been processed incorrectly here.
My question is: Can Xilix WebPack generate a bit file itself?
If not, how do I generate a bit file?
Thanks,
sneci
hm2/hm2_7i80.0: inconsistent Module Descriptor for UART Transmit Channel, not loading driverThe problem comes from the environment. The PIN file received from Peter has been processed incorrectly here.
Thanks,
sneci
Last edit: 01 Oct 2019 18:43 by sneci.
01 Oct 2019 19:43 #146824
Replied by PCW on topic Using pktuart with 7i80hd
Yes all my bitfiles are generated with the free Webpack
Are you sure you created a PktUART config?
The error suggests you have a standard UART config
(and the standard UART needs a Top level source file tweak = instance stride1
must be set to 16 rather than 64) The PktUART needs no tweak
- sneci
01 Oct 2019 20:51 #146827
by sneci
The convincing check was that I also made a bit file with your SVSTUA .. configuration. That also brought the error. It looks like the github is not compatible with mesanet packages.
Please take a look at the attached PKTUA pin configuration, I hope I didn't make a mistake.
01 Oct 2019 22:12 - 01 Oct 2019 22:30 #146835
Thats UART config (not PktUART) as I mentioned, you need to change the instance stride1
or you will get an error with UART configs (and UART config will have issues with Ethernet)
Last edit: 01 Oct 2019 22:30 by PCW.
- sneci
02 Oct 2019 20:14 #146894
by sneci
You're right, stride 1 is correct.
But unfortunately there were new problems.The pktuart.c component does not see the functions of hostmot2.c.
Unfortunately, I have to stop the much promising trial here. I am now solving this communication in user space. No more time now.
Thanks for the help
pktuart: dlopen: /home/ls/linuxcnc/rtlib/pktuart.so: undefined symbol: hm2_hz_to_mhzUnfortunately, I have to stop the much promising trial here. I am now solving this communication in user space. No more time now.
Thanks for the help
02 Oct 2019 20:57 - 02 Oct 2019 21:15 #146899
I dont think you are supposed to load the pktuart module (its part of hostmot2)
(I just tested with the mesa_pkt_gyro component and it loads properly)
Untill Hal adds a array or string type, dealing with UARTs will be awkward
Last edit: 02 Oct 2019 21:15 by PCW.
- sneci
02 Oct 2019 21:19 #146903
by sneci
That's really good news. I treated it as a normal hal component. I'll check it out tomorrow ...
Time to create page: 0.169 seconds
