Wiring a Chinese servo to a 7i77. Setup for yet another newbie
- kavindu1
09 Nov 2019 05:00 #149962
by kavindu1
Replied by kavindu1 on topic Wiring a Chinese servo to a 7i77. Setup for yet another newbie
i read your drive pdf your drive cn2 cabale out the A , B and Z plus out puts.
are u wire tease plus output to 7i77?
- SPH
- Thank you received: 6
09 Nov 2019 07:07 #149964
by SPH
Replied by SPH on topic Wiring a Chinese servo to a 7i77. Setup for yet another newbie
Not quite sure what you mean. Yes I have the A B and Z outputs wires into the 7i77.
- James Yother
03 Sep 2021 02:46 #219482
by James Yother
Replied by James Yother on topic Wiring a Chinese servo to a 7i77. Setup for yet another newbie
I'm trying to hook up the encoder to the acorn and what I don't know is where to hook the 5+VDC from the acorn encoder plug into the servo driver. what I do know is that on page 2.3.2 of the manual A+ is pin 20 A- is pin 19 B+ is pin 19 B- is pin 17 Z+ is pin 15 Z- is pin 16 GND is pin 1 and the only remaining pin is pin 22 and that is called OZ (Z open collector output) so I would thing that since that pin 22 is the only remaining pin; that it must be the 5+VDC for the encoder?????? oh man its always the last bolt you un-tighten that breaks off LOL on the acorn encoder plug it has pin 9=+5VDC pin7=A+ pin 8=B+ pin5=B- pin 6=Z+ pin 3=Z- pin 2=COM so it seems all so clear that A+ A- B+ B- Z+ Z- GND (COM) all have their places to connect to, but it's that 5+VDC pin 9 on the acorn that I dont know where to plug it in on the db25 connector on the servo driver, do you know if it plugs into the pin 22 OZ (Z open collector) please help, I am going crazy LOL
- Thank you received: 5326
03 Sep 2021 02:51 #219483
Replied by PCW on topic Wiring a Chinese servo to a 7i77. Setup for yet another newbie
The 5V is to power a standalone encoder.
If the servo has a simulated encoder output it does not need
5V so the 5V pin on the Acorn would be left unconnected
Time to create page: 0.292 seconds
