7i76 Error: BootSector is invalid
  • RobotMatic
  • RobotMatic's Avatar Topic Author
  • Elite Member
  • Elite Member
23 Dec 2019 17:07 #153120 by RobotMatic
7i76 Error: BootSector is invalid was created by RobotMatic
It is my first time with the 7i76e board, because of a defect in the cable assembly, the writing of the .bit file was interrupted, now it is an error BootSelector is invalid. How is it repaired? Thanks a lot
23 Dec 2019 17:27 #153122 by PCW
Replied by PCW on topic 7i76 Error: BootSector is invalid
1. if you power cycle the 7I76E, do you get a red /DONE LED?
2. if not, retry the firmware update
3. If you get a red /DONE LED on power up you can recover using the secondary flash memory:
A. Power done the 7I76E
B. Move the Jumper W9 to the "DOWN" = S position
C. Power up the 7I76E
D. Immediately move Jumper W9 to the "UP" = P position
E. retry the firmware update
F. NEVER update firmware with W9 in the DOWN = "S" position
Note that to fix a broken boot sector, you may need to add
mesaflashes --fix-boot-block option (depending on mesaflash version)
  • RobotMatic
  • Elite Member
  • Elite Member
23 Dec 2019 17:43 #153125 by RobotMatic
Replied by RobotMatic on topic 7i76 Error: BootSector is invalid
I have 3 red LEDs. that is good ?
23 Dec 2019 17:45 - 23 Dec 2019 17:51 #153126 by PCW
The red /DONE LED is the only one significant here
well that's no entirely true, if you have a red POWERFAIL LED illuminated, you have hardware issues
There are only 2 Red LEDs on a 7I76E card:
CR2 = /DONE
CR12 = PWR FAIL
There are three Yellow LEDs:
CR1 = INIT
CR8 = FIELD PWR
CR13 = PWR
and 4 Green "user" LEDs
Last edit: 23 Dec 2019 17:51 by PCW.
  • RobotMatic
  • Elite Member
  • Elite Member
23 Dec 2019 17:52 #153127 by RobotMatic
I have on the power led and the field pwr led, after turning off and on the 24v source
  • RobotMatic
  • Elite Member
  • Elite Member
23 Dec 2019 17:56 #153128 by RobotMatic
When linuxcnc starts up, the red INIT LED will light but it doesn't turn on DONE
What should I do exactly?
23 Dec 2019 18:04 #153129 by PCW
I'm a bit confused here
I thought you were trying to update the 7I76E firmware
  • RobotMatic
  • Elite Member
  • Elite Member
23 Dec 2019 18:10 #153130 by RobotMatic
yes !!! yes, that was what I was doing, I was writing the file 7i76e_7i76x3d.bit and it was interrupted, then I stayed in this situation
23 Dec 2019 18:12 #153131 by PCW
Did you succeed in updating the firmware?
  • RobotMatic
  • Elite Member
  • Elite Member
23 Dec 2019 18:35 #153132 by RobotMatic
no, I still have the same alarm
Moderators: PCW, jmelson
Time to create page: 0.912 seconds
