7i76 Error: BootSector is invalid
23 Dec 2019 18:46 - 23 Dec 2019 18:46 #153133 by PCW
Replied by PCW on topic 7i76 Error: BootSector is invalid
Did you include the --fix-boot-block mesaflash option when updating the firmware?
Last edit: 23 Dec 2019 18:46 by PCW.
The following user(s) said Thank You: RobotMatic
  • RobotMatic
  • RobotMatic's Avatar Topic Author
  • Elite Member
  • Elite Member
23 Dec 2019 20:53 - 23 Dec 2019 20:54 #153138 by RobotMatic
Replied by RobotMatic on topic 7i76 Error: BootSector is invalid
I managed to operate with W9 in fixed S. position. The P position lights red LED and does not allow Ethernet operation. In this situation, once it boot, I can change W9 from S to P. But there I don't know what to do to recover the main eprom.
Last edit: 23 Dec 2019 20:54 by RobotMatic.
23 Dec 2019 21:06 - 23 Dec 2019 21:06 #153139 by PCW
Then you run mesaflash to re-write the primary flash chip
something like
mesaflash --device 7i76e --fix-boot-block --write 7i76e_somebitfile.bit
Last edit: 23 Dec 2019 21:06 by PCW.
  • RobotMatic
  • Elite Member
  • Elite Member
26 Dec 2019 15:29 #153244 by RobotMatic
hi.
i am using
mesaflash --device 7i76e --fix-boot-block 7i76e_7i76x3D.bit
he answers me
ETH device 7I76-16 at ip=192.168.1.121
it's wrong ? I still have the same alarm
26 Dec 2019 15:34 #153245 by PCW
You did not include --write
  • RobotMatic
  • Elite Member
  • Elite Member
26 Dec 2019 15:50 #153246 by RobotMatic
Yes now!!. it was repaired! Thanks a lot. I owe you dear PCW.
Thanks a lot !!!
Thanks a lot !!!
Thanks a lot !!!
Thanks a lot !!!
Moderators: PCW, jmelson
Time to create page: 1.250 seconds
