Raspberry Pi 4 with Mesa 7c81
4 years 3 months ago #246840 by PCW
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
If 18" is long enough, Mesa's DB25M-IDC26 CABLE should be correct
4 years 2 months ago - 4 years 2 months ago #250689 by haziqiqbal9421@gmail.com
hey! i was following along and this thread was really helpful. I have a similar setup with RPi and Mesa 7c81 but I have 5-axis breakout board (HW356). This is how it looks like
.image missing https://hallroad.org/images/watermarked/detailed/25/MACH3_BREAKOUT_CNC_BOARD.jpg
I have selected "One Partport" in PNCconf but the parallel port options are very different from Stepconf. Could you please post a screenshot of parallel port configuration in pncconf for my breakout board. Thanks!
Last edit: 4 years 2 months ago by haziqiqbal9421@gmail.com.
4 years 2 months ago #250724 by PCW
You should select a parallel port like interface in pncconf, not a parallel port
(I would suggest the G540 option)
4 years 1 month ago #250993 by haziqiqbal9421@gmail.com
I have the following settings:
Base Information
Axis configuration: XYZ with Include Spindle
Mesa0 PCI/ Etho/ Partport with "One Partport"
Mesa 0
Board Name: 5i25-Internal Data
Firmware: G540x2
Num of encoder: 0
Nim of PWM: 0
Num of step generators: 3
And I have used I/O connector 3 which you said will be P1 on Mesa7c81.
Sorry I couldn't understand what you meant by "parallel port like". I would really appreciate your help.
4 years 1 month ago #251005 by PCW
The G540 _is_ a parallel port like configuration
(as opposed to a more complex configuration for a breakout like a 7I76 or 7I77)
4 years 1 month ago - 4 years 1 month ago #251235 by haziqiqbal9421@gmail.com
I guess I am still too dumb to understand. I have used G540 in firmware and edited in the hm2_pci to hm2_rpspi and hm2_5i25.0 to hm2_7c81.0 inĀ .hal and .ini file. What should I do with the partport? Should I use "One Partport" or "None" in pncconf?
Last edit: 4 years 1 month ago by haziqiqbal9421@gmail.com.
Moderators: PCW, jmelson
Time to create page: 0.580 seconds
