Raspberry Pi 4 with Mesa 7c81
5 years 6 months ago #205142 by JohnG
Replied by JohnG on topic Raspberry Pi 4 with Mesa 7c81
Absolutely. Will try it shortly.
I spent a lot of time reading about ferror last night and don't completely understand how that works on an open loop system...
5 years 6 months ago - 5 years 6 months ago #205154 by PCW
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
Mesa (and I think Pico systems) stepgens are actually run in closed loop mode
though the loop is closed in hal. Basically the step generators run in velocity mode
and the local PID loop monitors the actual step count (and fractional step count)
and adjusts for minor deviations caused by differences in LinuCNC and the stepgens
clocks, lack of frequency setting resolution etc etc.
Last edit: 5 years 6 months ago by PCW.
5 years 6 months ago #205160 by JohnG
It would appear that changing the ferror and min ferror values has solved the problem. I will run a few more tests to be confident. Much thanks again to PCW and andypugh! You guys are awesome!
5 years 6 months ago #205161 by JohnG
Also thanks for that explanation of the ferror. Makes total sense now that you said it's closed in hal. That was the part I was missing!
5 years 6 months ago - 5 years 6 months ago #205164 by PCW
Changing the ferror limit will have no effect on the motion _except_
it will trigger a following error and fault if the hardware stepgen gets
out of sync with the commanded position by greater than the limits.
I suggested reducing them to guarantee that the stepgen is doing what
its told (if not it would fault and stop motion)
5 years 6 months ago #205170 by JohnG
After reading this I get the impression that this shouldn't have fixed it? Is this only for and error message generator or does this actually control the maximum allowable error?
Moderators: PCW, jmelson
Time to create page: 0.289 seconds
