Back in this forum with an unusual issue that has me puzzled...
There is an issue with my router and circular cutting. When cutting arcs the machine is adding a small linear cut somewhere mid arc (see attached photos) In the photo marked A you can see that it was cutting a very nice arc then all of a sudden moves in a direction that is not part of the arc! I wrote very simple gcode program to test the arc in the part of the photo labeled A in an effort to eliminate the problem being a kCAD/CAM issue as this problem was originally discovered cutting an ellipse using CAD/CAM (label B in photo).
The axis are moving in the same direction throughout the arc which has eliminated backlash as the culprit.
Additionally I have been V carving with the machine and the results have been perfect (including curves of letters, picture shapes etc.)
This seems to be a problem with simple arcs
Totally stumped. Not sure if it’s settings or an issue with the 7c81. Any help would be greatly appreciated.
