Raspberry Pi 4 with Mesa 7c81
5 years 6 months ago #205025 by JohnG
Replied by JohnG on topic Raspberry Pi 4 with Mesa 7c81
It's totally strange. My thought is to try something to definitively say that it is not the 7c81 but I can not think of a way to do that. Open to suggestions for that or anything else!
5 years 6 months ago #205026 by JohnG
Not a loose coupling
One more thing I just thought of...
I reversed the cutting direction of the ellipse. In the opposite direction the error still occurred in the first and third curves. So no matter which direction it is moving it botches the first and third curves
5 years 6 months ago - 5 years 6 months ago #205032 by PCW
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
I still think its either mechanical or lost steps (drive related?) somehow.
Not really anything the 7C81 can do unless its fed a bogus trajectory that still obeys the
velocity and acceleration constraints and at the same time doesn't show up in the backplot.
Last edit: 5 years 6 months ago by PCW.
5 years 6 months ago #205036 by JohnG
I have checked everything mechanical. That was the easy part!
Also its too predictable in that it happens in the same places, curves one and three. I can manually command the machine back to zero and it is perfectly aligned. If I restart the program again it will do the same thing in the same place.
I just thought to try a G61 code...?
5 years 6 months ago #205047 by JohnG
After looking at the .ini file again I did notice that the MAX_VELOCITY values for the x and y axis are different as follows
X
MAX_VELOCITY = 1.01666666667
Y
MAX_VELOCITY = 1.0
I don't think this could cause the problem...
The acceleration, ferror, and min_ferror are the same for all axis
5 years 6 months ago #205112 by PCW
I some was thinking mm instead of inches
Can you set ferror to .002 and min ferror to .0005
and try again?
Moderators: PCW, jmelson
Time to create page: 0.150 seconds
