Raspberry Pi 4 with Mesa 7c81
5 years 9 months ago #195478 by JohnG
Replied by JohnG on topic Raspberry Pi 4 with Mesa 7c81
Thank you so much. I have made the changes. Last question... is it necessary to change all instances of 5l25 in these files to 7c81 or just the two instances that you mentioned?
5 years 9 months ago #195480 by PCW
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
There should only be one instance of "5i25" and it should be in the .ini file.
This is using the latest version of pncconf and there is a feature for having the
card name as a substitution (alias) from the .ini file:
5 years 9 months ago #195481 by JohnG
Reading through the Hal file there were several instances. Ex:
setp hm2_5i25.0.Stephen.04.dirsetup
I did not check the use ini substitution box in pncconf. Should I go back through and do that?
Or alternatively make all the changes in the Hal and ini files?
Thank you. This has been such a process and learning experience. Can’t wait to finally turn on the machine!
5 years 9 months ago #195483 by JohnG
*correction. Example should have read
setp hm2_5i25.0.stepgen.04.dirsetup
5 years 9 months ago #195487 by PCW
You can do it either way, I prefer the substitution way
rather than doing a global find/replace
5 years 9 months ago #195490 by JohnG
Huge thank you to PCW and andypugh! I have a functional cnc router! So grateful for the knowledge, quick responses and this forum.
Moderators: PCW, jmelson
Time to create page: 0.069 seconds
