Raspberry Pi 4 with Mesa 7c81
5 years 9 months ago #195097 by JohnG
Replied by JohnG on topic Raspberry Pi 4 with Mesa 7c81
Thank you so much!!!
Last question. I would like to load the G540 configuration. How do I do that?
Thank you again!!!
5 years 9 months ago - 5 years 9 months ago #195100 by andypugh
You would use mesaflash.
First you need the firmware file: You can download it from here:
store.mesanet.com/index.php?route=produc...oduct&product_id=338
Though, rather wierdly, it is on the "Specifications" tab as "Support software"
You will be wanting the 7c81_g540x2d.bit file.
Then flash it on to the card with Mesaflash. The closest I have found to documentation for Mesaflash is found by typing "mesaflash -h" at the command line.
Start with
mesaflash --device 7c81 --spi --readhmid
first to check connection and to see what firmware is already on there.
Then flash with
mesaflash --device 7c81 --spi --write 7c81_g540x2d.bit
(You will need to be in the directory where you put the bitfile)
Then either power-cycle the board, or use the mesaflash reset command.
Last edit: 5 years 9 months ago by andypugh.
5 years 9 months ago - 5 years 9 months ago #195102 by PCW
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
Read the current configuration:
sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --readhmid
(I would verify that this works reliably before trying to flash new firmware)
Write new firmware to the flash EEPROM:
sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --write 7c81_g540x2d.bit
Load the FPGA from the current flash EEPROM image:
sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --reload
Last edit: 5 years 9 months ago by PCW.
5 years 9 months ago #195105 by JohnG
Thank you so much for the help!
5 years 9 months ago #195107 by PCW
BTW the easiest way to generate a working hal/ini configuration for the 7C81 is to use
pncconf and setup say a 5I25+G540 configuration. Then change the card name in the .ini file
and driver name in the hal file
5 years 9 months ago #195175 by JohnG
Can’t thank you guys enough for all of your time and help. I have successfully installed Mesaflash but now when I try read from the 7c81 with these two options here are my results:
Results in “unrecognized option ‘—addr/dev/spidev0.0’”
sudo mesaflash --device 7c81 --spi --readhmid
Results in
“open: Bad address
No 7c81 board found”
Moderators: PCW, jmelson
Time to create page: 0.236 seconds
