Raspberry Pi 4 with Mesa 7c81
5 years 6 months ago #205172 by PCW
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
FERROR and MIN_FERROR are only for generating faults
from following errors. Following error is the difference between
commanded position and the actual position.
5 years 6 months ago #205173 by JohnG
Replied by JohnG on topic Raspberry Pi 4 with Mesa 7c81
Now Im even more puzzled! I will try to run some more tests later today
5 years 6 months ago #205711 by jaro_p
Can anyone please help with creating a bitfile?
I downloaded data from .mesanet.com.
I tried to create a bitfile using ISE Project Navigator, first in version 14.5 (P.58f), then in version 14.7 (P.20160913) for windows 10.
I tried to create a bitfile for different breakout boards. I did not make any changes, I used the original files. The process will always run with the message "completed successfully", but a bitfile will never be created.
I would need a bitfile for 7i78. I modified the file for 5i25. I don't know if this file is OK or what needs to be changed.
When creating the bitfile, I followed this gentleman - probably the best that can be found.
Thank you in advance for any advice.
5 years 6 months ago #205717 by PCW
Here is a bitfile for a 7C81 and 1 or 2 7I78s:
File Name: 7c81_7i78x2d.zip
File Size:109.68 KB
I have included the pinout file
If you are experimenting with making bitfiles, you should write them to the
fallback location on the cards flash memory, not the user location, because
if there is an error in your bitfile, you can brick the card. If you write the test bitfile to the
fallback location, you can just power cycle the card to get back to a working
configuration, rather than needing JTAG programmer to recover.
The following user(s) said Thank You: jaro_p
5 years 6 months ago #205718 by jaro_p
Thanks and I'm going for it.
5 years 6 months ago #205729 by jaro_p
Unfortunately, after the --readhmid command, I only get the message:
unable to set bpw32, fallback to bpw8
I tried to write the configuration:
mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --fallback --write /home/pi/Downloads/7c81/7c81_7i78x2d.bit
Checking file... OK
File type: BIT file
Boot sector OK
EEPROM sectors to write: 6, max sectors in area: 15
Erasing EEPROM sectors starting from 0x10000...
|EEEEEE
Programming EEPROM sectors starting from 0x10000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
Checking file... OK
File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x10000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board configuration verified successfully.
You must power cycle the hardware or use the --reload command to load a new firmware.
root@raspicnc-7c81:~# mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --reload
Waiting for FPGA configuration...OK
root@raspicnc-7c81:~# mesaflash --device 7c81 --addr /dev/spidev0.0 --spi readhmid
What does it mean? Why can't I read eeprom?
After the reboot, I only get the message again:
Moderators: PCW, jmelson
Time to create page: 0.199 seconds
