Strange issue with mesa 7i96 after machine go to endstop
11 Jun 2020 00:02 #171016 by PCW
Bad step/dir outputs and bad SSR output could be from excess voltage on the 5V power (6.5V or > will damage the ACT parts)
11 Jun 2020 00:10 - 11 Jun 2020 00:24 #171019 by alkabal
The DC/DC was calibrated 4.95 to 5.01 but after too much start stop i can imagine a problem occurs here with these new crappy supply.
Damned U3 U8 U16 have visible damage !
Can i ask what you suggest to replace ? (also U4 U7 ?)
I'm not lucky with Mesa card :pinch: some time ago i damaged the 7i76e spindle control don't know if you remenber :side:
Last edit: 11 Jun 2020 00:24 by alkabal.
11 Jun 2020 00:20 #171021 by alkabal
ACT
PLZK23 i found nothing
11 Jun 2020 23:56 #171194 by alkabal
Hi
Can you help for find the good component, i don't understand why google return nothing ?
Br
12 Jun 2020 00:31 #171196 by PCW
U3,U8,U16 are 74ACT04
U4 is 74ACT540 (TSSOP package)
U7 is 74ACT541 (TSSOP package )
The following user(s) said Thank You: alkabal
12 Jun 2020 01:05 - 12 Jun 2020 01:22 #171197 by alkabal
Last edit: 12 Jun 2020 01:22 by alkabal.
23 Jun 2020 22:55 #172514 by alkabal
Another thanks the7i96 work again with your help !
Soon i will try another attempt for use PID and velocity mode.
Br
Moderators: PCW, jmelson
Time to create page: 0.099 seconds
