Mesa 7i97 setup problem
- nighteagle
- Thank you received: 8
10 Feb 2022 12:23 #234504
by nighteagle
Replied by nighteagle on topic Mesa 7i97 setup problem
By the way
- i write an documentation for that complete configuration!
A Quick Beginners Guide for People with LinuxCNC and MESA-Cards like the 7i97.
I do this on every project - so i can remember things i'm doing in the past.
And here so many missing infos for BEginners - so i write my own Step-by-Step Guide.
So if someone can explain me how to put the infos later in the Wiki will be fine.
- Thank you received: 5337
10 Feb 2022 12:36 #234507
Replied by PCW on topic Mesa 7i97 setup problem
For a 7I97 (which is quite different from a 7I92/7I77 combo)
you should start with the "basic 7i97" config file set:
- nighteagle
10 Feb 2022 12:59 #234511
by nighteagle
@PCW,
yes i have found it above in the thread - and have changed ip to fit my card - so it works. Want to check out all Solutions for my Documentation also pncconf - by the way - the ip is here in the basic7i97 also the 192.168.1.121 not the 10.10.10.10.. it looks like there is more confusing with this sense of IP's.
But have i use an editor and simply configure by hand? That is very oldschool like Scotty say "Computer Hello Computer" to an mouse-input-device
But okay... will test it out...
10 Feb 2022 13:06 #234513
Yes, normally pncconf is just for creating a basic configuration file set,
you almost always need to edit the hal/ini files for customization.
- nighteagle
10 Feb 2022 13:20 #234517
by nighteagle
Okay,
i will read about all these config-values...
Thank you for your help..
- nighteagle
11 Feb 2022 06:57 - 11 Feb 2022 07:11 #234569
by nighteagle
Hello,
so one question... if i have the *.ini-file with the machine-setup and a hardware file like the *.hal - where can i configure which Pin of the Mesa 7i97 i connected with which function?
The 7i97 have:
P1 (Expansion),
TB1 (Encoders 0-2),
TB2(Encoders 3-5),
TB3(Analog Out),
TB4 (Input/RS422),
TB5 (I/O)
If i want to connect my Encoder from X-Axis to TB1 Encoder 0 - where can i do this? Is there a missing file for physical pin-mapping?
For example if i have P1 Pin 1 of the 7i97 then it is what for a name in hal? Or similar TB1 Encoder 0 is Pin 1 to 8 of the 7i97. So there is some mapping for that? Or an Overview of the HotMot Driver?
So here missing 7i97:
The 7i97 have:
P1 (Expansion),
TB1 (Encoders 0-2),
TB2(Encoders 3-5),
TB3(Analog Out),
TB4 (Input/RS422),
TB5 (I/O)
/usr/share/doc/hostmot2-firmware-<board>/
Last edit: 11 Feb 2022 07:11 by nighteagle.
11 Feb 2022 09:10 #234576
net x-pos-fb <= [HMOT](CARD0).encoder.00.position
net x-pos-fb => pid.x.feedback
This is done with these statements in the hal file:If i want to connect my Encoder from X-Axis to TB1 Encoder 0 - where can i do this? Is there a missing file for physical pin-mapping?
- nighteagle
11 Feb 2022 10:06 - 11 Feb 2022 10:11 #234583
by nighteagle
Yes i know - but what pin is what name? I see on the Card P1, TP1, Tp2... but in the HAL-File not? So somewhere a pin mapping?
Or a excel-table to see what pin of the mesa-card have what name for the hal-file... found nothing about this... my thoughts about this is some firmware-informations from mesa for the card - but in the folder there are missing many cards with there pin-mapping - for a mesa 7i43 there is a pin mapping file in the folder i wrote above.
Last edit: 11 Feb 2022 10:11 by nighteagle.
11 Feb 2022 10:11 #234584
The general TB pin to function mapping (for standard firmware) is in the manual,
and also reported by mesaflash (for any firmware).
- nighteagle
11 Feb 2022 10:26 #234587
by nighteagle
In the Mesa 7i97 Manual there is not any information about that.
On the Mesa-Website there is a link to Supported Software which contains also the basic hal and ini-files. But no mapping. I will contact mesa for that.
Thank you
Thank you
Time to create page: 1.368 seconds
