Simple IO wiring not working (I know I am doing something wrong)
  • Moderator
  • Moderator
03 Aug 2020 22:19 #177117 by tommylight
That diagram is wrong, it should be
power gnd to Mesa GND
power + through switch to Mesa input.
03 Aug 2020 22:48 #177120 by jhandel
Well that is going to be difficult given how the Proprietary Bob is designed from what I can gather..
I was really hoping I didn't have to tear out the IO BoB and rebuild the whole thing
03 Aug 2020 23:52 - 04 Aug 2020 00:03 #177127 by bevins
The 7i76 inmput needs to see 12v from field power connector for it to switch to true.
You dont have to tear it out, just put a relay to trigger off the bob output then pass the 12v of field power through the relay to the input of the 7i76.
I had the exact same scenario last year on a retrofit.worked like a charm.
Probably better to remove the bob and interface directly with the 7i76. Depending on your prox switches. PNP or NPN, one connects directly and the other you need some pullup resistors.
Last edit: 04 Aug 2020 00:03 by bevins.
04 Aug 2020 01:45 #177153 by jhandel
I'll have to dig through my transistor stash... I can flip the value via a transistor.. the trick will be making a package that is easy to make 20 some odd times and doesn't turn the box into a rats nest..
04 Aug 2020 07:33 #177191 by Clive S
Please see this: forum.linuxcnc.org/38-general-linuxcnc-q...oard?start=10#177142
04 Aug 2020 12:08 - 04 Aug 2020 12:08 #177220 by Mike_Eitel
Before you do anything hw:
1. If you use a switch that has 12v on one side and gnd on the other connected to the 7i76 input.. Can you see that toggling in hal? Don't move on with hw until you solved that.
2. Connect your bob to the same mesa input and measure with a real meter. Does it toggle. Yes = Do you see hal toggling too, problem solved
NO = 3. Is voltage not in full swing - try with resistor ca 1k if it gets better
A ) resistor from 12v to signal B ) signal to gnd
4. Eventually you have to lock for additional supply of bob.
Mike
Last edit: 04 Aug 2020 12:08 by Mike_Eitel.
04 Aug 2020 22:58 #177299 by jhandel
tommylight pull up resistors it is... It flips the logic so I'll need to use "not" input pins.. But tested with a 1kohm resistor and pull up resistors work consistantly..
Going to basically make a small breadboard like this (see attached image)..
So now to work out where it goes in the box.
  • Moderator
  • Moderator
04 Aug 2020 23:40 #177309 by tommylight
If you are ordering resistors, get them at 2.2K or 4.7K and 1/4W.
1K will do just fine for 12V, but in case you need to raise that to 24, you would need bigger resistors at 0.5W
05 Aug 2020 01:33 #177330 by jhandel
lucky for me all of my inputs are 12v because they are coming off of that BoB.. I did try 2.2k and 4.7 and they didn't work... but 1k worked consistently... So at least for this machine that "should" work.. .
  • Moderator
  • Moderator
05 Aug 2020 09:23 #177369 by tommylight
.. I did try 2.2k and 4.7 and they didn't work... but 1k worked consistently... .. .
Nice to know that, thank you.
Moderators: PCW, jmelson
Time to create page: 0.167 seconds
