7i92h with 7i77, 7i74,7i71,7i70,7i73
04 Oct 2020 15:58 #184835 by PCW
Replied by PCW on topic 7i92h with 7i77, 7i74,7i71,7i70,7i73
That's the parameter name but what's the value?
05 Oct 2020 01:50 #184907 by Thods1222
Replied by Thods1222 on topic 7i92h with 7i77, 7i74,7i71,7i70,7i73
Owner:28, type: u32, Dir:R0, value:0x00000003
05 Oct 2020 01:56 #184910 by PCW
Can you start LinuxCNC and run this command in a terminal:
halcmd show all > all.txt
and post all.txt here?
05 Oct 2020 02:35 #184918 by Thods1222
Here is the output of the all.txt.
File Name: all.txt
File Size:93 KB
05 Oct 2020 02:59 #184920 by PCW
Ack, I didn't think there were any with that firmware revision released.
It should be possible to update the firmware in place. The sserial.tg
file has all the required files but I'm not sure if the scripts will work
with sserial port 1. I will take a look tomorrow.
freeby.mesanet.com/software/parallel/sserial.tgz
06 Oct 2020 19:29 #185121 by Thods1222
I wonder if it would be easier to do an RMA and cycle this back for the firmware update since it seems I have a problematic card.
06 Oct 2020 19:38 #185125 by PCW
Probably, there's something odd about a 03 revision as I don't think any cards with rev. 03 firmware actually shipped.
If you email Mesa with a RMA request I will issue a RMA #
11 Oct 2020 13:58 #185713 by Thods1222
Ok, I shipped it back. It should be to you on Tuesday. Thanks for your help.
13 Oct 2020 23:52 #186041 by PCW
OK, fixed.
It is a really old card (8-9 years?) so the 03 version was probably legitimate
but probably best updated here as its so old the remote firmware
update method might have failed.
The following user(s) said Thank You: Thods1222
14 Oct 2020 00:27 #186046 by Thods1222
It looks like we made the right call by sending it back for the update. Thanks for your help.
Moderators: PCW, jmelson
