7c80 install on rpi 4
- chernogorsky
21 Apr 2023 14:38 #269556
by chernogorsky
Replied by chernogorsky on topic 7c80 install on rpi 4
I think its appropriate to continue in that topic (if not, I'll create a new one)
I have strange issue with 7c80,
Im configuring spindle. Spindleout works finally,
but I cant configure ENA/DIR isolated output
I configured them as
setp hm2_7c80.0.gpio.020.invert_output true
setp hm2_7c80.0.gpio.020.is_output true
setp hm2_7c80.0.gpio.021.invert_output true
setp hm2_7c80.0.gpio.021.is_output true
net spindle-cw => hm2_7c80.0.gpio.020.out
net spindle-ccw => hm2_7c80.0.gpio.021.out
I see that it works in a halmon once I enable it
But it does not enable the pins on a TB5
another point (not sure if it should be so) is that in the readhmid I see the following (no secondary function):
TB5-2 18 IOPort PWM 0 PWM (Out)
TB5-2 19 IOPort PWM 0 /Enable (Out)
TB5-5,6 20 IOPort None
TB5-7,8Internal 21 IOPort None
Any idea toward the error in my DNA ?
- Thank you received: 5334
21 Apr 2023 15:16 #269557
Replied by PCW on topic 7c80 install on rpi 4
The ENA/DIR or FWD/REV outputs are switches, not voltage outputs
so must be tested with a ohmmeter or switching a load.
- chernogorsky
21 Apr 2023 15:45 #269558
by chernogorsky
you, thats how I connect it, as a switch
and it does not connect it once TRUE, ohmmeter shows line disconnect
21 Apr 2023 15:48 #269559
Do inputs GPIO20 and GPIO21 show low when the corresponding outputs are set true?
- chernogorsky
21 Apr 2023 15:51 #269561
by chernogorsky
Im not sure I know how to check that ? could you point me to the right command ?
- chernogorsky
21 Apr 2023 16:00 #269562
by chernogorsky
If its the output of halmon, than yes
(with spindle enable in lcnc)
36 bit OUT TRUE hm2_7c80.0.gpio.020.in
36 bit OUT FALSE hm2_7c80.0.gpio.020.in_not
21 Apr 2023 16:01 #269563
halshow
watch tab
watch tab
- chernogorsky
21 Apr 2023 16:07 #269564
by chernogorsky
21 Apr 2023 16:23 - 21 Apr 2023 16:28 #269565
means disabled
This is because the outputs that drive the OPTOs are active low.
This is why you invert the outputs so setting GPIO 20 output pin
high gives an low output state.
means disabled
Last edit: 21 Apr 2023 16:28 by PCW.
- chernogorsky
21 Apr 2023 16:27 #269566
by chernogorsky
Return back inverted mode
36 bit OUT TRUE hm2_7c80.0.gpio.020.in_not
36 bit IN TRUE hm2_7c80.0.gpio.020.out <== spindle-cw
Same - no switching between EN+/EN-
Time to create page: 0.380 seconds
