Debugging sporadic read errors from Mesa 7i95
- piranha32
25 Oct 2020 06:18 #187171
by piranha32
Debugging sporadic read errors from Mesa 7i95 was created by piranha32
Hello,
I get sporadic read errors from my Mesa card, and I would like ask for an advice how to debug them.
The card most of the time works fine, but when I leave linuxcnc running, after some time, from several hours to a day or two, communication stops, and I get an error similar to this:
hm2/hm2_7i95.0: error finishing read! iter=79413542
Besides showing the error and killing communication, everything else seems to work ok (LinuxCNC does not crash). During the this time system is completely idle, with screen blanked.
Card is connected directly to the ethernet port on the computer, everything is sitting on my desk in office-like conditions (no heavy EMI), all peripherals are disconnected from the board.
The card is powered from the same 5V power supply as the computer.
The system runs on AtomicPi board with Atom x5-Z8350, OS is Debian 10.6 with kernel 4.19.0-11-rt-amd64 #1 SMP PREEMPT RT, installed from live LinuxCNC image. LinuxCNC version is 2.9.0-pre0 installed from Github source.
Thank you,
p
Thank you,
p
- BeagleBrainz
- Visitor
25 Oct 2020 09:27 #187178
by BeagleBrainz
Replied by BeagleBrainz on topic Debugging sporadic read errors from Mesa 7i95
What are the Amperage rating of the PSU for the Atomic Pi ?
- Thank you received: 5290
25 Oct 2020 19:55 #187214
Replied by PCW on topic Debugging sporadic read errors from Mesa 7i95
Can you run this command:
halcmd show all *.tmax
with LinuxCNC running and post the results along with the CPU speed?
- BeagleBrainz
- Visitor
25 Oct 2020 20:53 #187216
by BeagleBrainz
I know from the redit forums that many people aren't using the recommended PSU for the Atomic Pi. The sellers recommend a 5v 4A supply. If the OP has a borderline PSU would this be a contributing factor to the errors he is seeing ? He does mention both the Atomic Pi & 7i95 are powered by the same supply.
Or would it be that the board is a little underpowered CPU wise ?
25 Oct 2020 21:10 - 25 Oct 2020 21:10 #187220
It could be power supply related. It could also be
power management that has not been disabled,
or the CPU is just slow (a 2 ms Servo thread might solve the issue)
Last edit: 25 Oct 2020 21:10 by PCW.
- piranha32
25 Oct 2020 21:12 #187221
by piranha32
Replied by piranha32 on topic Debugging sporadic read errors from Mesa 7i95
3A. This is more than what I received in the "full devel kit" (2.5A)What are the Amperage rating of the PSU for the Atomic Pi ?
- piranha32
25 Oct 2020 21:18 #187222
by piranha32
I'll power the board from a separate PS, and see what will happen.
The PSU is more powerful than what I received in the AtomicPi devel kit. It is a bit strange, because everything worked fine under load, with all motors and peripherals runningI know from the redit forums that many people aren't using the recommended PSU for the Atomic Pi. The sellers recommend a 5v 4A supply. If the OP has a borderline PSU would this be a contributing factor to the errors he is seeing ? He does mention both the Atomic Pi & 7i95 are powered by the same supply.
- piranha32
25 Oct 2020 21:32 #187226
by piranha32
CPU runs at 1.68GHz. Motion runs without problems, system doesn't feel underpowered.
Here is the output from "halcmd show all *.tmax"
$ ~/build/linuxcnc-dev/scripts/rip-environment halcmd show all *.tmax
Loaded HAL Components:
ID Type Name PID State
Component Pins:
Owner Type Dir Value Name
Pin Aliases:
Alias Original Name
Signals:
Type Value Name (linked to)
Parameters:
57 s32 RW 23940 comp_x.tmax
57 s32 RW 21528 comp_y.tmax
57 s32 RW 23364 comp_z.tmax
23 s32 RW 25236 ddt_x.tmax
23 s32 RW 21852 ddt_xv.tmax
23 s32 RW 28818 ddt_y.tmax
23 s32 RW 23076 ddt_yv.tmax
23 s32 RW 24354 ddt_z.tmax
23 s32 RW 26928 ddt_zv.tmax
65 s32 RW 0 hm2_7i95.0.read-request.tmax
65 s32 RW 1216764 hm2_7i95.0.read.tmax
65 s32 RW 170118 hm2_7i95.0.write.tmax
34 s32 RW 36342 limit_speed.tmax
19 s32 RW 26946 motion-command-handler.tmax
19 s32 RW 160434 motion-controller.tmax
40 s32 RW 23040 near_speed.tmax
54 s32 RW 24426 or2_0.tmax
43 s32 RW 25740 rpm_rps.tmax
20 s32 RW 1265814 servo-thread.tmax
31 s32 RW 34200 sim_spindle.tmax
37 s32 RW 27306 spindle_mass.tmax
26 s32 RW 48546 vel_xy.tmax
26 s32 RW 24624 vel_xyz.tmax
Parameter Aliases:
Alias Original Name
Exported Functions:
Owner CodeAddr Arg FP Users Name
Realtime Threads:
Period FP Name ( Time, Max-Time )Please Log in or Create an account to join the conversation.
- piranha32
25 Oct 2020 21:35 #187227
by piranha32
Installing OS from the live LinuxCNC image I did not expect any power saving mechanisms, and cpufreqd is not even installed, but I'll try to force performance governor and see if it will help.
- BeagleBrainz
- Visitor
25 Oct 2020 21:43 #187230
by BeagleBrainz
I've always used a min of 4amp supply for the Atomic Pi. Many of the brick type PSUs hve what may be called "exaggerated" specs, so I've always tended to go a little higher when using them.
Time to create page: 0.239 seconds
