Debugging sporadic read errors from Mesa 7i95
- Thank you received: 7448
25 Oct 2020 21:46 #187231
Replied by tommylight on topic Debugging sporadic read errors from Mesa 7i95
Take PCW's advice, edit the ini file in your config directory, locate the servo period and change it from 1000000 (1 million) to 2000000 (2 million), save and start LinuxCNC again.
- Clive S
- Thank you received: 486
25 Oct 2020 22:17 #187237
by Clive S
I think you will have to change the P 1000 to 500 as well
Replied by Clive S on topic Debugging sporadic read errors from Mesa 7i95
- piranha32
25 Oct 2020 22:24 #187239
by piranha32
Replied by piranha32 on topic Debugging sporadic read errors from Mesa 7i95
I increased servo thread period to 2 000 000. It this doesn't help, I'll experiment with power supplies. One change at a time.
- piranha32
25 Oct 2020 22:25 #187240
by piranha32
What is P?I think you will have to change the P 1000 to 500 as well
25 Oct 2020 22:29 #187242
P value for each joint/axis in the same ini file further down.
- Clive S
25 Oct 2020 22:32 #187244
by Clive S
It is a parameter in the ini file.
- piranha32
25 Oct 2020 22:41 #187246
by piranha32
To be clear, I get the timeouts in the sim environment, and in configuration driving physical steppers.
Ah, I see. I'm currently running sim environment (axis_mm) to play with simple I/O on the card, and it does not even specify PID parameters. Should I add it?P value for each joint/axis in the same ini file further down.
26 Oct 2020 07:40 #187280
What PC ?
- BeagleBrainz
- Visitor
26 Oct 2020 07:53 #187282
by BeagleBrainz
Replied by BeagleBrainz on topic Debugging sporadic read errors from Mesa 7i95
The OP is using an Atomic Pi. It's a rebranded Atom based SBC that was destined for a household robot. It was marketed as an x86 challenger to the RPi. Bought by a lot of the "maker types". The sub reddit is kinda funny, so many bought them without reading the mass of data sheets and info the reseller has/had of their site. Biggest problem was people not being ale to read the instructions on how to power it. At the time it was USD $35 so kinda cheap for a x86 SBC. If you had a bit of common sense and were willing to read the docs it was easy to get to work. If you wanted a "turn key" x86 SBC it wasn't the thing you should have bought.
Mine is sitting in the corner ATM....work bench is kinda chocka block full, need to finish a few projects to make room.
www.digital-loggers.com/api_faqs.html
Time to create page: 0.097 seconds
