Debugging sporadic read errors from Mesa 7i95
25 Oct 2020 06:18 #187171 by piranha32
Hello,
I get sporadic read errors from my Mesa card, and I would like ask for an advice how to debug them.
The card most of the time works fine, but when I leave linuxcnc running, after some time, from several hours to a day or two, communication stops, and I get an error similar to this:
hm2/hm2_7i95.0: error finishing read! iter=79413542
Besides showing the error and killing communication, everything else seems to work ok (LinuxCNC does not crash). During the this time system is completely idle, with screen blanked.
Card is connected directly to the ethernet port on the computer, everything is sitting on my desk in office-like conditions (no heavy EMI), all peripherals are disconnected from the board.
The card is powered from the same 5V power supply as the computer.
The system runs on AtomicPi board with Atom x5-Z8350, OS is Debian 10.6 with kernel 4.19.0-11-rt-amd64 #1 SMP PREEMPT RT, installed from live LinuxCNC image. LinuxCNC version is 2.9.0-pre0 installed from Github source.
Thank you,
p
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
25 Oct 2020 09:27 #187178 by BeagleBrainz
Replied by BeagleBrainz on topic Debugging sporadic read errors from Mesa 7i95
What are the Amperage rating of the PSU for the Atomic Pi ?
25 Oct 2020 19:55 #187214 by PCW
Can you run this command:
halcmd show all *.tmax
with LinuxCNC running and post the results along with the CPU speed?
  • BeagleBrainz
  • Visitor
  • Visitor
25 Oct 2020 20:53 #187216 by BeagleBrainz
I know from the redit forums that many people aren't using the recommended PSU for the Atomic Pi. The sellers recommend a 5v 4A supply. If the OP has a borderline PSU would this be a contributing factor to the errors he is seeing ? He does mention both the Atomic Pi & 7i95 are powered by the same supply.
Or would it be that the board is a little underpowered CPU wise ?
25 Oct 2020 21:10 - 25 Oct 2020 21:10 #187220 by PCW
It could be power supply related. It could also be
power management that has not been disabled,
or the CPU is just slow (a 2 ms Servo thread might solve the issue)
Last edit: 25 Oct 2020 21:10 by PCW.
25 Oct 2020 21:12 #187221 by piranha32
Replied by piranha32 on topic Debugging sporadic read errors from Mesa 7i95
3A. This is more than what I received in the "full devel kit" (2.5A)
25 Oct 2020 21:18 #187222 by piranha32
The PSU is more powerful than what I received in the AtomicPi devel kit. It is a bit strange, because everything worked fine under load, with all motors and peripherals running
I'll power the board from a separate PS, and see what will happen.
25 Oct 2020 21:32 #187226 by piranha32
CPU runs at 1.68GHz. Motion runs without problems, system doesn't feel underpowered.
Here is the output from "halcmd show all *.tmax"
$ ~/build/linuxcnc-dev/scripts/rip-environment halcmd show all *.tmax
Loaded HAL Components:
ID      Type  Name                                            PID   State
Component Pins:
Owner   Type  Dir         Value  Name
Pin Aliases:
 Alias                                            Original Name
Signals:
Type          Value  Name     (linked to)
Parameters:
    57  s32   RW          23940  comp_x.tmax
    57  s32   RW          21528  comp_y.tmax
    57  s32   RW          23364  comp_z.tmax
    23  s32   RW          25236  ddt_x.tmax
    23  s32   RW          21852  ddt_xv.tmax
    23  s32   RW          28818  ddt_y.tmax
    23  s32   RW          23076  ddt_yv.tmax
    23  s32   RW          24354  ddt_z.tmax
    23  s32   RW          26928  ddt_zv.tmax
    65  s32   RW              0  hm2_7i95.0.read-request.tmax
    65  s32   RW        1216764  hm2_7i95.0.read.tmax
    65  s32   RW         170118  hm2_7i95.0.write.tmax
    34  s32   RW          36342  limit_speed.tmax
    19  s32   RW          26946  motion-command-handler.tmax
    19  s32   RW         160434  motion-controller.tmax
    40  s32   RW          23040  near_speed.tmax
    54  s32   RW          24426  or2_0.tmax
    43  s32   RW          25740  rpm_rps.tmax
    20  s32   RW        1265814  servo-thread.tmax
    31  s32   RW          34200  sim_spindle.tmax
    37  s32   RW          27306  spindle_mass.tmax
    26  s32   RW          48546  vel_xy.tmax
    26  s32   RW          24624  vel_xyz.tmax
Parameter Aliases:
 Alias                                            Original Name
Exported Functions:
Owner   CodeAddr  Arg       FP   Users  Name
Realtime Threads:
     Period  FP     Name               (     Time, Max-Time )
25 Oct 2020 21:35 #187227 by piranha32
Installing OS from the live LinuxCNC image I did not expect any power saving mechanisms, and cpufreqd is not even installed, but I'll try to force performance governor and see if it will help.
  • BeagleBrainz
  • Visitor
  • Visitor
25 Oct 2020 21:43 #187230 by BeagleBrainz
I've always used a min of 4amp supply for the Atomic Pi. Many of the brick type PSUs hve what may be called "exaggerated" specs, so I've always tended to go a little higher when using them.
Moderators: PCWjmelson
Time to create page: 0.092 seconds
