Mesa 7I76e - Two power supplies or one?
  • txtrone
  • txtrone's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 Nov 2020 18:09 #188826 by txtrone
I noticed the 7I76e can be powered using both 24v and 5v ... is that recommended? I have it powered using 5v only at the moment, nothing besides my PC connected. Just curious what the normal setup is? I will be using this card for a plasma table.
09 Nov 2020 20:54 #188838 by Benb
Replied by Benb on topic Mesa 7I76e - Two power supplies or one?
you need 5v and 24v PS. The following link contains wiring diagrams that might help you.
forum.linuxcnc.org/27-driver-boards/3191...nnection-sheet#83565
09 Nov 2020 21:07 #188839 by PCW
Replied by PCW on topic Mesa 7I76e - Two power supplies or one?
You can use 5V and 24V or a single 24V supply.
There is also the option of using separate field and FPGA logic power
if you want isolation between the FPGA section and the field I/O section
10 Nov 2020 02:12 #188845 by rodw
Replied by rodw on topic Mesa 7I76e - Two power supplies or one?
While its not necessary, I run seperate 5V and 24V power supplies. I think next time, I would just use the 24V power supply.
I would just add 24V field power to what you have now. You don't need a big power supply. Around 2 amps is fine.
  • txtrone
  • Platinum Member
  • Platinum Member
10 Nov 2020 07:09 #188867 by txtrone
Replied by txtrone on topic Mesa 7I76e - Two power supplies or one?
Ok, I will add 24V ... there is a jumper I need to change to run both 5v and 24v, at least I am pretty sure I read that somewhere. I will check the manual.
  • txtrone
  • Platinum Member
  • Platinum Member
10 Nov 2020 17:24 #188937 by txtrone
If using 24v only, should I use the same 24v PS to provide power to the TB1 field power AND TB3? Or do I need to somehow separate that incoming power? Or have it coming from two sources?
10 Nov 2020 17:33 #188940 by PCW
Normally I would just use one power supply unless you want the field
I/O section to be isolated for noise reasons.
  • txtrone
  • Platinum Member
  • Platinum Member
10 Nov 2020 17:49 #188943 by txtrone
Ok, but does the one power supply need to connect at both TB1 and TB3? The way that the 'Anschluss' drawing shows? Or am I misreading the schematic? Relevant portion attached.
Thanks!
10 Nov 2020 18:46 #188944 by PCW
Yes you would need to connect to TB1 (Field Power) and TB3 (unregulated logic power for the FPGA side)
  • txtrone
  • Platinum Member
  • Platinum Member
10 Nov 2020 18:52 #188945 by txtrone
Thanks! I flipped the switch and no smoke!
Moderators: PCW, jmelson
Time to create page: 0.123 seconds
